    yummy
      What did you do with your 42lb'ers?
        Currently trying to sell them..
          Anyone know of a fuel pump set up that I could use to flow enough? I only have 1 Walbro 255 and I don't think it will be enough.
          • 240sxguy2
            240sxguy2
            240sxguy
            I run a pair of 255s in my 240sx. The bosch 044 would be a good choice. I also run -8 feed and dual -6 returns (used both stock feed/return as returns)
            EDIT; I read back and see your looking for 400hp. I would do a bosch 044 pump.
              How much for the injectors?
                Currently have a bid for 200 on them.
                  Thanks man! So Walbro in tank, and then 044 in line or something?
                    Bought some condor speed shop mounts, trans and motor. Also bought a ps delete from them.
                      Anyone have an e34 oil pickup tube and dipstick? Or even just the dipstick?
                        Blaine0002
                        Looks like were doing a similar build then :D
                        Ive got a vanos m50 with NV rods and pistons, .140 mls headgasket, arp head and main studs.. aiming for about 400 hp! :D
                        ben do you have skype? I need some advice!
                          I do!
                          So many turbo builds....
                            Blaine0002
                            text it to me! :D
                              Text, I never saved your number
                                Hopefully I only need e85, stock head gasket, and arp's to get me to 400 :D
                                  Blaine0002
                                  please dont go stock hg
                                    Why wouldn't I? I don't need to lower the compression at all.
                                      Blaine what are you running for management/manifold?
                                      • 240sxguy2
                                        240sxguy2
                                        240sxguy
                                        Single 044 in tank should be okay for you. I run a pair of 255s in tank. It's a clusterfuck and if one pump fails I am not gonna be happy.
                                          Well if I already have a 255, I'm going to install it. So should I run another 255 inline or something?
