    I should still be able to support 500+ hp with e85 with these injectors though :D
      yes please
        yummy
          What did you do with your 42lb'ers?
            Currently trying to sell them..
              Anyone know of a fuel pump set up that I could use to flow enough? I only have 1 Walbro 255 and I don't think it will be enough.
              • 240sxguy2
                240sxguy2
                240sxguy
                I run a pair of 255s in my 240sx. The bosch 044 would be a good choice. I also run -8 feed and dual -6 returns (used both stock feed/return as returns)
                EDIT; I read back and see your looking for 400hp. I would do a bosch 044 pump.
                  How much for the injectors?
                    Currently have a bid for 200 on them.
                      Thanks man! So Walbro in tank, and then 044 in line or something?
                        Bought some condor speed shop mounts, trans and motor. Also bought a ps delete from them.
                          Anyone have an e34 oil pickup tube and dipstick? Or even just the dipstick?
                            Blaine0002
                            Looks like were doing a similar build then :D
                            Ive got a vanos m50 with NV rods and pistons, .140 mls headgasket, arp head and main studs.. aiming for about 400 hp! :D
                            ben do you have skype? I need some advice!
                              I do!
                              So many turbo builds....
                                Blaine0002
                                text it to me! :D
                                  Text, I never saved your number
                                    Hopefully I only need e85, stock head gasket, and arp's to get me to 400 :D
                                      Blaine0002
                                      please dont go stock hg
                                        Why wouldn't I? I don't need to lower the compression at all.
                                          Blaine what are you running for management/manifold?
