    Rowleym said:
    I should still be able to support 500+ hp with e85 with these injectors though :D
    yes please
      yummy
        What did you do with your 42lb'ers?
          Currently trying to sell them..
            Anyone know of a fuel pump set up that I could use to flow enough? I only have 1 Walbro 255 and I don't think it will be enough.
            • 240sxguy2
              240sxguy2
              240sxguy
              I run a pair of 255s in my 240sx. The bosch 044 would be a good choice. I also run -8 feed and dual -6 returns (used both stock feed/return as returns)
              EDIT; I read back and see your looking for 400hp. I would do a bosch 044 pump.
                How much for the injectors?
                  Currently have a bid for 200 on them.
                    Thanks man! So Walbro in tank, and then 044 in line or something?
                      Bought some condor speed shop mounts, trans and motor. Also bought a ps delete from them.
                        Anyone have an e34 oil pickup tube and dipstick? Or even just the dipstick?
                          Blaine0002
                          Looks like were doing a similar build then :D
                          Ive got a vanos m50 with NV rods and pistons, .140 mls headgasket, arp head and main studs.. aiming for about 400 hp! :D
                          ben do you have skype? I need some advice!
                            I do!
                            So many turbo builds....
                              Blaine0002
                              text it to me! :D
                                Text, I never saved your number
                                  Hopefully I only need e85, stock head gasket, and arp's to get me to 400 :D
                                    Blaine0002
                                    please dont go stock hg
                                      Why wouldn't I? I don't need to lower the compression at all.
                                        Blaine what are you running for management/manifold?
                                        • 240sxguy2
                                          240sxguy2
                                          240sxguy
                                          Single 044 in tank should be okay for you. I run a pair of 255s in tank. It's a clusterfuck and if one pump fails I am not gonna be happy.
