    The only thing i have left to buy is intercooler piping, oil feed(I have the fittings), do i need to relocate the oil filter? Most people did with m20's. And i have to hook up my oil cooler. Thats about it. and buy mounts and stuff.. I will definitely let you know though
      Get injectors yet? I might have a set of freshly rebuilt 42lb'ers
        No I have 42lbers. Anyways. Little update I guess? I've been finishing up my Volkswagen recently, and tearing into my father son project. We pulled the tub off the frame in the cj7, looking to buy a YJ tub, powder coat the frame, run new brake lines/fuel lines, rebuild the brakes, add about a 3 inch lift with some fender flares to hopefully put some 35's or maybe 33's. Re-ring and bearings for the AMC 360 coming in, carb rebuild(that was a first for me) and I guess that's about it? I will be finishing the heap before I put time into the bimmer. I have lots of time for the bimmer, but My father and I are taking a trip to Colorado camping when I graduate so I want this bitch to be done. That is all.
          Little update. Sold the DIYPNP and wasted spark setup in like 10 hours. Bought ms3x with Jim stim and 80# Injectors. I'll be running cop on the m50 with sequential injection. Me gusta e85
            O__O
            Are you encountering any other M50 turbo guys running injectors that size? you must be shooting for 500-600hp, no?
              Haha I wish. I'm actually just shooting for around 400, but I'm using e85, so I need around 30% more fuel!
                Gotcha. I am not too savvy with cornfuel but what you said makes sense based on its energy concentration in relation to the good ol' stuff.
                  I should still be able to support 500+ hp with e85 with these injectors though :D
                    yes please
                      yummy
                        What did you do with your 42lb'ers?
                          Currently trying to sell them..
                            Anyone know of a fuel pump set up that I could use to flow enough? I only have 1 Walbro 255 and I don't think it will be enough.
                            • 240sxguy2
                              240sxguy2
                              240sxguy
                              I run a pair of 255s in my 240sx. The bosch 044 would be a good choice. I also run -8 feed and dual -6 returns (used both stock feed/return as returns)
                              EDIT; I read back and see your looking for 400hp. I would do a bosch 044 pump.
                                How much for the injectors?
                                  Currently have a bid for 200 on them.
                                    Thanks man! So Walbro in tank, and then 044 in line or something?
                                      Bought some condor speed shop mounts, trans and motor. Also bought a ps delete from them.
                                        Anyone have an e34 oil pickup tube and dipstick? Or even just the dipstick?
                                          Blaine0002
                                          Looks like were doing a similar build then :D
                                          Ive got a vanos m50 with NV rods and pistons, .140 mls headgasket, arp head and main studs.. aiming for about 400 hp! :D
                                          ben do you have skype? I need some advice!
