    Get injectors yet? I might have a set of freshly rebuilt 42lb'ers
      No I have 42lbers. Anyways. Little update I guess? I've been finishing up my Volkswagen recently, and tearing into my father son project. We pulled the tub off the frame in the cj7, looking to buy a YJ tub, powder coat the frame, run new brake lines/fuel lines, rebuild the brakes, add about a 3 inch lift with some fender flares to hopefully put some 35's or maybe 33's. Re-ring and bearings for the AMC 360 coming in, carb rebuild(that was a first for me) and I guess that's about it? I will be finishing the heap before I put time into the bimmer. I have lots of time for the bimmer, but My father and I are taking a trip to Colorado camping when I graduate so I want this bitch to be done. That is all.
        Little update. Sold the DIYPNP and wasted spark setup in like 10 hours. Bought ms3x with Jim stim and 80# Injectors. I'll be running cop on the m50 with sequential injection. Me gusta e85
          O__O
          Are you encountering any other M50 turbo guys running injectors that size? you must be shooting for 500-600hp, no?
            Haha I wish. I'm actually just shooting for around 400, but I'm using e85, so I need around 30% more fuel!
              Gotcha. I am not too savvy with cornfuel but what you said makes sense based on its energy concentration in relation to the good ol' stuff.
                I should still be able to support 500+ hp with e85 with these injectors though :D
                  yes please
                    yummy
                      What did you do with your 42lb'ers?
                        Currently trying to sell them..
                          Anyone know of a fuel pump set up that I could use to flow enough? I only have 1 Walbro 255 and I don't think it will be enough.
                          • 240sxguy2
                            240sxguy2
                            240sxguy
                            I run a pair of 255s in my 240sx. The bosch 044 would be a good choice. I also run -8 feed and dual -6 returns (used both stock feed/return as returns)
                            EDIT; I read back and see your looking for 400hp. I would do a bosch 044 pump.
                              How much for the injectors?
                                Currently have a bid for 200 on them.
                                  Thanks man! So Walbro in tank, and then 044 in line or something?
                                    Bought some condor speed shop mounts, trans and motor. Also bought a ps delete from them.
                                      Anyone have an e34 oil pickup tube and dipstick? Or even just the dipstick?
                                        Blaine0002
                                        Looks like were doing a similar build then :D
                                        Ive got a vanos m50 with NV rods and pistons, .140 mls headgasket, arp head and main studs.. aiming for about 400 hp! :D
                                        ben do you have skype? I need some advice!
                                          I do!
                                          So many turbo builds....
