  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 7.2k Views 4 Watching
    USAIR event was today.
    took 8th/120 in raw time and 2nd in class
    course was identical to the one in the spring - the start and finish were in the same spots lol.
    In the spring I drove the evo and went 61.2, this event I went 62.0 - super happy with how this car is setup now
      Cool that you got lucky with the same track setup for comparison.
        More pics from USAIR.
        dyno day this Saturday, interested to see what this car makes before plopping the s52 in it
          Plotting The Simpsons GIF
            Dyno day got cancelled lol
              Almost ready to drop the m52.
              Need to remove: Fuel lines, heater core hoses & front suspension (to make it easier to manage on a jack)
                Dropping it out of the bottom Is the way to go
                ABS pump is already gone, as well as all the front brake lines. Working on getting the bias adjuster mounted and remote cable ran.
                quick bend of the rear line gets the angle right for the cable to run to an already existing grommet in the firewall next to the main fuse box harness
                  Interior stuff is all done, remote Knob used the area for the fog lights (which Are being removed for the OEM “delete” panels)
                  hoping I won’t have to touch interior stuff anymore for this chapter (wideband is already routed, just not connected to anything)
                  made a quick “bracket” for the bias adjuster out of some scrap 3/4” alum square tubing.
                  removed the factory heat shield for the exhaust (firewall area, still running the one in the tunnel) as it was pretty disgusting and had seen better days.
                  Eventually I’ll add some DEI stuff if needed. Also removed the factory sound deadening thing from the firewall/tunnel. After removing the flanged plastic nuts the stuff basically fell apart as I removed it. It was also gross. Have seen rot behind these before on other cars, but luckily this car has never seen winter. Removed all the studs with an angle grinder as well.
                  should have a lot more room to access trans stuff now if I need to.
                  next up is to finish making hardlines to go from master to bias valve and master to front brakes. Once that’s done I can start on the engine stuff
                    Master to bias line done for rear brakes
                      Drivers side front brake line good to go, passenger line will be the longest run from the T4257271A-960E-4843-A92A-BE18AC89FA3F.jpeg
                      might even be able to use the stock brake line metal clip things with a little finesse
                        Hardlines are finished
                        Next up is s52 stuff I think
                          This done yet?
                            This done yet?
                            Lol
                              Solid lifter conversion is about 99.9% done. Cams were in and out a bunch while setting lash.
                              this kit uses the stock lifter/hydraulic adjuster, but the hydraulic adjuster is basically gutted and you use shims that are .010” and .008” thickness
                              stock adjuster removed from lifter
                              dropping in shims
                              and back in the trays
                              still using the stock s52 cams for now
                                So happy you finished this. What's next? Putting everything else on?
                                  Timing chains/timing cover/time it/oil pan/gaskets etc etc etc
                                    Ended up pulling the intake side to reshim 2 lifters, all back together & timed now
                                    FCP order showing up soonish for some stuff that I either misplaced or never ordered.
                                      Looks fantastic, nice work!
                                        Popped the front main in, installed the damper (still need to torque that, which basically means set the impact to max and send it home) engine is on the subframe now, m20 FW on with arp hardware, new spec clutch/pressure plate,TOB/PB, clutch pivot pin with grease fitting, trans put on, new control arms, bushings, etc etc 5140E845-79D0-4F4C-BFAF-788F1333C95E.jpeg6D479B9A-1D20-4217-ACCB-7D1CF0DB2B7D.jpeg8AA47068-9D58-4C26-A9DB-E549EFB872E0.jpeg
                                        @Rekpointis stopping by to help toss this thing in
                                        side note, this hikfab plate has probably saved me from purchasing around 70 oil pans AEBC33A5-FF37-4BBF-AD77-EDB729CAD296.jpeg5B950114-3B06-4BFD-BBB5-F83490AF8E2E.jpeg
                                        it did pick up a slight bend, but I’m going to toss it in the press to see if I can’t straighten it back out a bit
                                        also, say no to brass pivot pins lol. This maybe had like 4k miles on it - was previously running a south bend stg3 street clutch/pp
                                          What’s the one on the left made out of? Is that a grease zerk that I see on it?
