  4. ‘91 E30
‘91 E30
510 Posts 27 Posters 7.2k Views 4 Watching
    Day 2. Took 3rd in XSB behind a codriven 2.5 swapped NC. Couldn’t catch them lol
    13/93 in raw time
    http://fvscc.com/results/2021_Summer/event9_raw.htm
      Found some more pics from the event
        USAIR event was today.
        took 8th/120 in raw time and 2nd in class
        course was identical to the one in the spring - the start and finish were in the same spots lol.
        In the spring I drove the evo and went 61.2, this event I went 62.0 - super happy with how this car is setup now
          Cool that you got lucky with the same track setup for comparison.
            More pics from USAIR.
            dyno day this Saturday, interested to see what this car makes before plopping the s52 in it
              Plotting The Simpsons GIF
                Dyno day got cancelled lol
                  Almost ready to drop the m52.
                  Need to remove: Fuel lines, heater core hoses & front suspension (to make it easier to manage on a jack)
                    Dropping it out of the bottom Is the way to go
                    ABS pump is already gone, as well as all the front brake lines. Working on getting the bias adjuster mounted and remote cable ran.
                    quick bend of the rear line gets the angle right for the cable to run to an already existing grommet in the firewall next to the main fuse box harness
                      Interior stuff is all done, remote Knob used the area for the fog lights (which Are being removed for the OEM “delete” panels)
                      hoping I won’t have to touch interior stuff anymore for this chapter (wideband is already routed, just not connected to anything)
                      made a quick “bracket” for the bias adjuster out of some scrap 3/4” alum square tubing.
                      removed the factory heat shield for the exhaust (firewall area, still running the one in the tunnel) as it was pretty disgusting and had seen better days.
                      Eventually I’ll add some DEI stuff if needed. Also removed the factory sound deadening thing from the firewall/tunnel. After removing the flanged plastic nuts the stuff basically fell apart as I removed it. It was also gross. Have seen rot behind these before on other cars, but luckily this car has never seen winter. Removed all the studs with an angle grinder as well.
                      should have a lot more room to access trans stuff now if I need to.
                      next up is to finish making hardlines to go from master to bias valve and master to front brakes. Once that’s done I can start on the engine stuff
                        Master to bias line done for rear brakes
                          Drivers side front brake line good to go, passenger line will be the longest run from the T4257271A-960E-4843-A92A-BE18AC89FA3F.jpeg
                          might even be able to use the stock brake line metal clip things with a little finesse
                            Hardlines are finished
                            Next up is s52 stuff I think
                              This done yet?
                                This done yet?
                                Lol
                                  Solid lifter conversion is about 99.9% done. Cams were in and out a bunch while setting lash.
                                  this kit uses the stock lifter/hydraulic adjuster, but the hydraulic adjuster is basically gutted and you use shims that are .010” and .008” thickness
                                  stock adjuster removed from lifter
                                  dropping in shims
                                  and back in the trays
                                  still using the stock s52 cams for now
                                    So happy you finished this. What's next? Putting everything else on?
                                      Timing chains/timing cover/time it/oil pan/gaskets etc etc etc
                                        Ended up pulling the intake side to reshim 2 lifters, all back together & timed now
                                        FCP order showing up soonish for some stuff that I either misplaced or never ordered.
                                          Looks fantastic, nice work!
