  4. 540i Swapped Rat rod Build thread
91 Posts 14 Posters 1.6k Views 1 Watching
  • ThatRatRodProjectT
    ThatRatRodProjectT
    ThatRatRodProject
    RobZR said:
    I would not recommend using a stripper bolt in this manner. They are not intended to handle lateral forces and have a inherent stress riser at the base of the thread that is prone to failure.
    Ideally you would support both sides of the pivot point from the subframe.  if you must support it from one side a spool and bolt design will bend before failure, since it keeps the bolt in tension.
    I 100% agree with you. If you are using a Harden alloy shoulder bolt. But with that being said I will be mostly turning up a custom shoulder bolt . But any side load should be transferred to linear load with the thrust bearings. Not 100% transferred but lessened a great deal. I’m not saying you wrong in anyway and I will take any input I can.
      CAD to Metal overnight. I like your fast pace.
      What did you use to cut the parts? Waterjet?
        ThatRatRodProjectT
        ThatRatRodProject
        I work In a Tool Shop so i May have utilized Our CNC Laser.
        I did have some of this work done Prior to posting the cad up date.
        Its been after hours progress the past 2 weeks . I have 3 of the 4 Control Arms done. So you should see up-dates later this week.
          ThatRatRodProjectT
          ThatRatRodProject
          Update.
          I gotta finish welding up the last control arm but here’s 3 of them.
          I used 3d printed jigs to replicate the tube lengths and made up a quick fixture.
          AD34B246-ADD6-4A4C-8B34-FB7E0FD25502.MP4
          • AD34B246-ADD6-4A4C-8B34-FB7E0FD25502.MP4
            Chugga chugga. I cant wait to see the whole assembly!
              ThatRatRodProjectT
              ThatRatRodProject
              I got a lot of welding to do on the subframes but hopefully soon. My ball joints are on back order sadly.
                ThatRatRodProjectT
                ThatRatRodProject
                All 4 done and ready to go. They will be powder coated in the future but first I gotta get some mock-up done.
                  ThatRatRodProjectT
                  ThatRatRodProject
                  RobZR said:
                  With some help from RobZR. I believe we have reached a much safer option from using a shoulder bolt. I made up this spindle design last night. This will have a castle nut and cotter pin in its end form. I did tighten it all down and I’m very pleased with how it turned out. zero play.
                    Great work man! You may also consider using oil impregnated solid thrust washers instead of roller bearing thrust washers if the loads are low enough and you want to improve environmental protection.
                    The castle nut is a great idea
                      ThatRatRodProjectT
                      ThatRatRodProject
                      I would like to possible try 3d Printing some bushings for weather protection. Out of some soft filament. Or Nylon
                        ThatRatRodProjectT
                        ThatRatRodProject
                        Quick up date.
                        Got some of my hardware to assemble my front end just waiting on ball joints and got a finish up some welding
                          ThatRatRodProjectT
                          ThatRatRodProject
                          Happy thanksgiving update. This is gonna be a Picture update. Photos might not all be in order.
                          IMG_1238.MOV
                          IMG_1253.MP4
                          IMG_1259.MOV
                          • IMG_1238.MOV
                          • IMG_1253.MP4
                          • IMG_1259.MOV
                            ThatRatRodProjectT
                            ThatRatRodProject
                            Pulled the frame out from underneath the car and worked on getting the front end mounted to the frame. Holiday week is letting me get some shop time in. I’m just waiting on the rear wheels  From basset racing. and then I will have everything to make it a roller. Glad to see all me card board templates and napkin drawings are working out.
                              ThatRatRodProjectT
                              ThatRatRodProject
                              Today’s progress flipped the frame back over and set the body back on. Dropped the motor in and line up the drive line components.
                              Up next motor mounts and rear sub frame modification. I have to finish weld the the front subframe. And waiting on rear wheel from bassets racing.  So I can start string lining gauging for. Rear sub Frame mounts.
                              IMG_1269.MP4
                              • IMG_1269.MP4
                                ThatRatRodProjectT
                                ThatRatRodProject
                                Sunday progress motor mounts done (wil have small pad between mounts. Next up is transmission mounts should be easy lots of room. Then to the rear subframe where heavy modifying will need to happen.
                                IMG_1275.MP4 IMG_1276.MP4 IMG_1277.MP4
                                • IMG_1275.MP4
                                • IMG_1276.MP4
                                • IMG_1277.MP4
