  4. 540i Swapped Rat rod Build thread
91 Posts 14 Posters 1.6k Views 1 Watching
  • ThatRatRodProjectT
    ThatRatRodProjectT
    ThatRatRodProject
    Nice work! Solidworks?
    I have so many questions.(Sorry) Is there a reason you are going with a cantilever set up? How did you calculate the the pivot arm length? Are there any shear concerns with the shock mounted on the top of the tube like that without any linear support? You obviously peaked my interest. I like what I see and I am very glad this isn't a dead thread.
    Yes the Cad software i use is Solid-works.
    There is a couple reasons why I'm using a cantilever.
    1. I have the coil-over mounted horizontally To Keep it Clear of road Hazards like Dirt, rocks, Ect.
    2. I am using a under rated spring. So with the Cantilever allows me to achieve my desired spring rate with some sacrifice of overall suspension Travel.  Because i honestly don't know what the project will weigh in at.  I may have to re-fabricate the Cantilever Section. But This may be to stiff.
    Attached is a image of a section View of the Cantilever.
    The stack up is From the top Down.
    Stripper Bolt (Shear Strength of  82,000 Psi (Roughly 28,000 Pounds or shear force))
    Harden Washer
    Thrust Bearing
    Harden Washer
    Normal Ball Bearing
    Mounting piece (Gets Welded into the Cantilever)
    Normal Ball Bearing
    Harden Washer
    Thrust Bearing
    Harden Washer
    Mounting Blacking (will get mounted to the end of the tubing, (Tubing will likely be gusseted in the future)
    • Quote
    • Edit
      ThatRatRodProjectT
      ThatRatRodProject
      Yeah this project was always intriguing, but has certainly caught more of my interest seeing things being modeled!
      The shear area on that upper shock mount seems reasonable if you've got good penetration welds on both plates.
      I think I saw the knuckles in a picture on a previous page, but are those a standard purchased component?
      I've always thought it would be cool to do a ground up build like this, so I really look forward to the continuation of this!
      The Knuckle is a ford Pinto Spindle. Primarily Used in circle track applications.
        ThatRatRodProjectT
        ThatRatRodProject
        Quick update. with some actual fab work being done.
        The past couple weeks I have been putting in some hours gettin some of the front frame done. I’m gonna attach some photos if you have any questions let me know. I’ll try to explain.
        68146F60-B7C9-405D-9388-5EEEE2580392.MP4
        3313FB85-223C-4B49-A9BD-F9EC8D2293C1.MOV 65AD28E0-186E-4B34-8577-045E1CC9E60F.MP4 9070B11F-FE72-4710-8BD4-5062AADA8845.MP4 BC8E10B8-81C0-4EF0-8CC0-98251DCCA8DB.MP4
          ThatRatRodProjectT
          ThatRatRodProject
          87C94C13-2CBA-459A-B93C-C9D60E18578E.MOV
          • 87C94C13-2CBA-459A-B93C-C9D60E18578E.MOV
          • RobZRR
            RobZRR
            RobZR
            ThatRatRodProject said:
            I would not recommend using a stripper bolt in this manner. They are not intended to handle lateral forces and have a inherent stress riser at the base of the thread that is prone to failure.
            Ideally you would support both sides of the pivot point from the subframe.  if you must support it from one side a spool and bolt design will bend before failure, since it keeps the bolt in tension.
              ThatRatRodProjectT
              ThatRatRodProject
              I 100% agree with you. If you are using a Harden alloy shoulder bolt. But with that being said I will be mostly turning up a custom shoulder bolt . But any side load should be transferred to linear load with the thrust bearings. Not 100% transferred but lessened a great deal. I’m not saying you wrong in anyway and I will take any input I can.
                CAD to Metal overnight. I like your fast pace.
                What did you use to cut the parts? Waterjet?
                  ThatRatRodProjectT
                  ThatRatRodProject
                  I work In a Tool Shop so i May have utilized Our CNC Laser.
                  I did have some of this work done Prior to posting the cad up date.
                  Its been after hours progress the past 2 weeks . I have 3 of the 4 Control Arms done. So you should see up-dates later this week.
                    ThatRatRodProjectT
                    ThatRatRodProject
                    Update.
                    I gotta finish welding up the last control arm but here’s 3 of them.
                    I used 3d printed jigs to replicate the tube lengths and made up a quick fixture.
                    AD34B246-ADD6-4A4C-8B34-FB7E0FD25502.MP4
                    • AD34B246-ADD6-4A4C-8B34-FB7E0FD25502.MP4
                      Chugga chugga. I cant wait to see the whole assembly!
                        ThatRatRodProjectT
                        ThatRatRodProject
                        I got a lot of welding to do on the subframes but hopefully soon. My ball joints are on back order sadly.
                          ThatRatRodProjectT
                          ThatRatRodProject
                          All 4 done and ready to go. They will be powder coated in the future but first I gotta get some mock-up done.
                            ThatRatRodProjectT
                            ThatRatRodProject
                            RobZR said:
                            With some help from RobZR. I believe we have reached a much safer option from using a shoulder bolt. I made up this spindle design last night. This will have a castle nut and cotter pin in its end form. I did tighten it all down and I’m very pleased with how it turned out. zero play.
                              Great work man! You may also consider using oil impregnated solid thrust washers instead of roller bearing thrust washers if the loads are low enough and you want to improve environmental protection.
                              The castle nut is a great idea
                                ThatRatRodProjectT
                                ThatRatRodProject
                                I would like to possible try 3d Printing some bushings for weather protection. Out of some soft filament. Or Nylon
                                  ThatRatRodProjectT
                                  ThatRatRodProject
                                  Quick up date.
                                  Got some of my hardware to assemble my front end just waiting on ball joints and got a finish up some welding
                                    ThatRatRodProjectT
                                    ThatRatRodProject
                                    Happy thanksgiving update. This is gonna be a Picture update. Photos might not all be in order.
                                    IMG_1238.MOV
                                    IMG_1253.MP4
                                    IMG_1259.MOV
                                    • IMG_1238.MOV
                                    • IMG_1253.MP4
                                    • IMG_1259.MOV
                                      ThatRatRodProjectT
                                      ThatRatRodProject
                                      Pulled the frame out from underneath the car and worked on getting the front end mounted to the frame. Holiday week is letting me get some shop time in. I’m just waiting on the rear wheels  From basset racing. and then I will have everything to make it a roller. Glad to see all me card board templates and napkin drawings are working out.
                                        ThatRatRodProjectT
                                        ThatRatRodProject
                                        Today’s progress flipped the frame back over and set the body back on. Dropped the motor in and line up the drive line components.
                                        Up next motor mounts and rear sub frame modification. I have to finish weld the the front subframe. And waiting on rear wheel from bassets racing.  So I can start string lining gauging for. Rear sub Frame mounts.
                                        IMG_1269.MP4
                                        • IMG_1269.MP4
                                          ThatRatRodProjectT
                                          ThatRatRodProject
                                          Sunday progress motor mounts done (wil have small pad between mounts. Next up is transmission mounts should be easy lots of room. Then to the rear subframe where heavy modifying will need to happen.
                                          IMG_1275.MP4 IMG_1276.MP4 IMG_1277.MP4
                                          • IMG_1275.MP4
                                          • IMG_1276.MP4
                                          • IMG_1277.MP4
