  4. ‘91 E30
‘91 E30
    Fixed the oil leak from the bummerworld distroblock, the temp sensor I added in the t stat housing doesn’t seem to be leaking any more. It’s back home. Still Need to replace the valve cover gasket, it’s pissing oil - just waiting on some parts
      Mission accomplished 👍
        A lot of screwing around for a different trans
          A good trans/good shifting  is so important though.
          a fresh clutch bleed, redline atf and removing the CDV made the biggest difference in driving enjoyment in the E46
              Exhaust getting wrapped up
                What kind of muffler is that?
                  Magnaflow something. Whatever comes on the bummerworld race exhaust
                    Still leaking oil, but driving. should be getting the vc grommets today in the mail
                    exhaust went ok. It’s routed a bit goofy and isn’t tucked up as high as it could be, but it’s enough clearance for now and for $80 I can’t complain. This will be something in the future I will have modified to fit up against the car.
                      Also wired all the gauges last night. Went all out with the label maker
                      turns out the oil psi sender I have is most likely junk as the gauge pegs Max with key on. (Does this with sender wire connected and disconnected). The gauges all use the same power and ground and the other 2 work perfectly. New sender shows up tomorrow
                        Junk. Throw it against the wall and try again.
                          Looking good! How does it sound though?
                            Sure, I stop coming to visit and this thing's starts moving under its own power.  I see how it is.
                              It’s ok. Haven’t heard it from outside yet
                                Passed this up to co drive the evo at the last auto x event. Which is probably good because I need to get things to 100% before taking this thing out in an environment like that.
                                Evo was still a bunch of fun
                                  All those driven wheels though...
                                    It makes me not want to own anything old and just buy tires/brake pads and go have worry free fun
                                      New sender fixed the issue. @Rekpoint you can throw it against your own wall if you’d like
                                        It would probably start working 😅
                                          A first for me today, car fell off the jack as I was raising it up from the skid plate. It was odd, it just spit the jack out the front. Got lodged in between the valence and the core support. Barely pushed the valence out, blew the lip off and took some coating off a wire loom. Got lucky.
