  4. ‘91 E30
‘91 E30
    Time to start planning on what's going to put it out of commission for the 2020 driving season!
      You’re my favorite type of person
        Love you boo 😘
          Fixed the oil leak from the bummerworld distroblock, the temp sensor I added in the t stat housing doesn’t seem to be leaking any more. It’s back home. Still Need to replace the valve cover gasket, it’s pissing oil - just waiting on some parts
            Mission accomplished 👍
              A lot of screwing around for a different trans
                A good trans/good shifting  is so important though.
                a fresh clutch bleed, redline atf and removing the CDV made the biggest difference in driving enjoyment in the E46
                    Exhaust getting wrapped up
                      What kind of muffler is that?
                        Magnaflow something. Whatever comes on the bummerworld race exhaust
                          Still leaking oil, but driving. should be getting the vc grommets today in the mail
                          exhaust went ok. It’s routed a bit goofy and isn’t tucked up as high as it could be, but it’s enough clearance for now and for $80 I can’t complain. This will be something in the future I will have modified to fit up against the car.
                            Also wired all the gauges last night. Went all out with the label maker
                            turns out the oil psi sender I have is most likely junk as the gauge pegs Max with key on. (Does this with sender wire connected and disconnected). The gauges all use the same power and ground and the other 2 work perfectly. New sender shows up tomorrow
                              Junk. Throw it against the wall and try again.
                                Looking good! How does it sound though?
                                  Sure, I stop coming to visit and this thing's starts moving under its own power.  I see how it is.
                                    It’s ok. Haven’t heard it from outside yet
                                      Passed this up to co drive the evo at the last auto x event. Which is probably good because I need to get things to 100% before taking this thing out in an environment like that.
                                      Evo was still a bunch of fun
                                        All those driven wheels though...
                                          It makes me not want to own anything old and just buy tires/brake pads and go have worry free fun
