  4. Tossed a different set of wheels on the 240 today...
266 Posts 28 Posters 0 Views 1 Watching
  • The Full BananaT
    The Full BananaT
    The Full Banana
    Thanks, guys! Uh oh, just realized I might have a roadblock from putting this engine in this weekend. I need 6mm dowel pins for the flywheel/pressure plate. Crap.
      Can you pull the ones from the FW I sent you or are they a different size?
      • The Full BananaT
        The Full BananaT
        The Full Banana
        Hmmm, good thought. I'll have to take a look.
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Well, I checked the e36 dowel pins this morning before work, and they are too big.
          however, I think I should be alright... Dustin to the rescue!
          • The Full BananaT
            The Full BananaT
            The Full Banana
            Big ol' calipers.
            • The Full BananaT
              The Full BananaT
              The Full Banana
              Engine and trans are queued up and ready to go in after I get some work done on the e36.
              (The dirty stuff was just on for mockup and timing for flywheel indexing)
                Looking great!  Excited to see this thing in person sometime.
                  should have drawn a dick on the flywheel prior to assembly.
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    Thanks. I can't wait to drive it this spring!
                    Maybe I did. #secretsobscuredbythebellhousing
                    Anyways, the engine/trans are in. I had to make a bracket to mount the power steering pump today, but didn't take a picture.
                    Anyone know a good place to have custom power steering lines made up? Or should I just go the route of a compression fitting to AN?
                      Hyquip does all sorts of custom hoses, most even made while you wait. I would definitely check them out first. Looking good by the way!
                        Someone engraved a dick on my strut tower.....
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          Awesome, that's on my way home from work. I'll have to check them out. Thanks!
                          • ClassEC
                            ClassEC
                            ClassE
                            No idea how I haven't seen this thread yet! Project looks fantastic - love the coupes!!!
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              very cool, i like this lots
                                Can't wait to see this in person!  Super clean bay!  Epic wire tuck.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Thanks guys! I'll crash a BMW meet or two in this car this summer... park on the street or something. I can't wait for the meet "season" to get going.
                                  Progress and such. In-fender wiring pretty far along now. Waiting for the intake manifold to show up to finalize all the wiring that will be hidden under that.
                                    Looking topnotch as usual! Can not wait to see this car in person!
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      Thanks TJ
                                      Test-fit with the intake manifold. looks like the new fuel rail interferes with the strut brace, so that'll take some figuring.
                                      Freshened up (thanks DP)
                                      BRAKES
                                      These 17" RCs barely clear the caliper. Perhaps a bit close for comfort.
                                        I thought my brake setup was cutting it close.  e46 330i brakes (325mm) with 16" contour reps.  I have less than 1/4" clearance.  From the pic it looks like tons of room for the caliper.
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          The picture does look roomy, especially with the adapters on there. There is 1/16"-3/32" clearance between the caliper and the barrel of the wheel. It's VERY tight.
