  • The Full BananaT
    The Full BananaT
    The Full Banana
    wasnt m3 said:
    Wow, this is coming a long way! What color is the bay sprayed?
    It's Duplicolor Engine Enamel 'Cast Coat Iron' with a whole bunch of clear and wax on top.
    It's a really goofy color. Looks a lot different depending on the lighting. In natural light it's a dark grey, and incandescent light brings out a lot more greenish brown. Certainly different, but I like it. I wanted some amount of contrast with the exterior paint while still being somewhat neutral.
      That's what my block is painted with. Great choice. When are you planning to throw the motor in?
      • The Full BananaT
        The Full BananaT
        The Full Banana
        Hoping to drop it in next weekend. I just need to clean and paint a few brackets.
        • The Full BananaT
          The Full BananaT
          The Full Banana
          Quick couple things: (the other things I don't have pictures of yet)
          Tossed on the new 330mm rotors (Volvo S60R) and threw a RC over top to get an idea.
          modified Volvo bellhousing with adapter plate to mate to my getrag 265
          Engine complete-enough to go in.
            Looking good!
              Dat in-jun doe.
                I thought you were going to drop the engine in a few weekends ago? =P
                  RC's are gonna look great on that car :) Can't wait to see the engine in that beautiful bay.
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    Thanks, guys! Uh oh, just realized I might have a roadblock from putting this engine in this weekend. I need 6mm dowel pins for the flywheel/pressure plate. Crap.
                      Can you pull the ones from the FW I sent you or are they a different size?
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        Hmmm, good thought. I'll have to take a look.
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          Well, I checked the e36 dowel pins this morning before work, and they are too big.
                          however, I think I should be alright... Dustin to the rescue!
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Big ol' calipers.
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Engine and trans are queued up and ready to go in after I get some work done on the e36.
                              (The dirty stuff was just on for mockup and timing for flywheel indexing)
                                Looking great!  Excited to see this thing in person sometime.
                                  should have drawn a dick on the flywheel prior to assembly.
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Thanks. I can't wait to drive it this spring!
                                    Maybe I did. #secretsobscuredbythebellhousing
                                    Anyways, the engine/trans are in. I had to make a bracket to mount the power steering pump today, but didn't take a picture.
                                    Anyone know a good place to have custom power steering lines made up? Or should I just go the route of a compression fitting to AN?
                                      Hyquip does all sorts of custom hoses, most even made while you wait. I would definitely check them out first. Looking good by the way!
                                        Someone engraved a dick on my strut tower.....
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          Awesome, that's on my way home from work. I'll have to check them out. Thanks!
