    should have drawn a dick on the flywheel prior to assembly.
    Someone engraved a dick on my strut tower.....
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Bassboy3313 said:
      Hyquip does all sorts of custom hoses, most even made while you wait. I would definitely check them out first. Looking good by the way!
      Awesome, that's on my way home from work. I'll have to check them out. Thanks!
        No idea how I haven't seen this thread yet! Project looks fantastic - love the coupes!!!
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          very cool, i like this lots
            Can't wait to see this in person!  Super clean bay!  Epic wire tuck.
            • The Full BananaT
              The Full BananaT
              The Full Banana
              Thanks guys! I'll crash a BMW meet or two in this car this summer... park on the street or something. I can't wait for the meet "season" to get going.
              Progress and such. In-fender wiring pretty far along now. Waiting for the intake manifold to show up to finalize all the wiring that will be hidden under that.
                Looking topnotch as usual! Can not wait to see this car in person!
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  Thanks TJ
                  Test-fit with the intake manifold. looks like the new fuel rail interferes with the strut brace, so that'll take some figuring.
                  Freshened up (thanks DP)
                  BRAKES
                  These 17" RCs barely clear the caliper. Perhaps a bit close for comfort.
                    I thought my brake setup was cutting it close.  e46 330i brakes (325mm) with 16" contour reps.  I have less than 1/4" clearance.  From the pic it looks like tons of room for the caliper.
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      The picture does look roomy, especially with the adapters on there. There is 1/16"-3/32" clearance between the caliper and the barrel of the wheel. It's VERY tight.
                        On the bright side, it will be an automatic indicator if a wheel gets bent.
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          Getting more things done.
                          Mocking up the intercooler--not yet mounted.
                          Intercooler pipes fitted.
                          Roundit 2000 for the harness and misc other wiring
                          Odyssey PC680 mounted and other bits
                            Good progress!  I like the sneaky battery mounting
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              Thanks, I'm going to use a e36 distribution block/positive terminal in the engine bay. Should be a nice little detail.
                                I hope you make it out to the E30 meet on May 10th.
                                This car is awesome
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  If you guys don't mind me bringing a non-BMW, I'd like to swing by. We'll see though, that is two days before I take this car on a 35 hour drive to Portland, OR for a Volvo car show.
                                    That should be a great drive! Are you taking I80 or I90?
                                    Did you come up with that oil cooler bracket or is that original?
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      We are just going to start figuring out the route now. At the moment, I have no idea... but I'm very open to suggestions! We will probably be stopping in Kansas City on the way out.
                                      That oil cooler is a factory piece from a mid-year turbo car. It fits rather nicely with the factory intercooler in place, but the endtanks on this one block it more than I would like. I may try a bit of ducting to direct air to it... or I'll eventually put an oil cooler below the radiator. I have an oil temp gauge so I can keep an eye on it (Not that it should present any problem).
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        I'm tired and it's late so I'm not going to write much.
                                        I've been working on this a lot, and had help this weekend. A couple friends came over and swapped in the rear end from the wagon while I worked on other stuff.
                                        (oil lines aren't going to just hang there... have to wrap and mount them still)
                                        this one is for Dave.
                                        Goal was to start it today but that didn't happen because I was missing a few little bits and pieces that local stores didn't have. I'm going to get this thing legal to drive this week... it won't be long now.
                                          Looking great!  Did it always have the remote oil filter?
