  4. 540i Swapped Rat rod Build thread
91 Posts 14 Posters 1.6k Views 1 Watching
    Chugga chugga. I cant wait to see the whole assembly!
    • ThatRatRodProjectT
      ThatRatRodProjectT
      ThatRatRodProject
      I got a lot of welding to do on the subframes but hopefully soon. My ball joints are on back order sadly.
        ThatRatRodProjectT
        ThatRatRodProject
        All 4 done and ready to go. They will be powder coated in the future but first I gotta get some mock-up done.
          ThatRatRodProjectT
          ThatRatRodProject
          RobZR said:
          With some help from RobZR. I believe we have reached a much safer option from using a shoulder bolt. I made up this spindle design last night. This will have a castle nut and cotter pin in its end form. I did tighten it all down and I’m very pleased with how it turned out. zero play.
            Great work man! You may also consider using oil impregnated solid thrust washers instead of roller bearing thrust washers if the loads are low enough and you want to improve environmental protection.
            The castle nut is a great idea
              ThatRatRodProjectT
              ThatRatRodProject
              I would like to possible try 3d Printing some bushings for weather protection. Out of some soft filament. Or Nylon
                ThatRatRodProjectT
                ThatRatRodProject
                Quick up date.
                Got some of my hardware to assemble my front end just waiting on ball joints and got a finish up some welding
                  ThatRatRodProjectT
                  ThatRatRodProject
                  Happy thanksgiving update. This is gonna be a Picture update. Photos might not all be in order.
                  IMG_1238.MOV
                  IMG_1253.MP4
                  IMG_1259.MOV
                  • IMG_1238.MOV
                  • IMG_1253.MP4
                  • IMG_1259.MOV
                    ThatRatRodProjectT
                    ThatRatRodProject
                    Pulled the frame out from underneath the car and worked on getting the front end mounted to the frame. Holiday week is letting me get some shop time in. I’m just waiting on the rear wheels  From basset racing. and then I will have everything to make it a roller. Glad to see all me card board templates and napkin drawings are working out.
                      ThatRatRodProjectT
                      ThatRatRodProject
                      Today’s progress flipped the frame back over and set the body back on. Dropped the motor in and line up the drive line components.
                      Up next motor mounts and rear sub frame modification. I have to finish weld the the front subframe. And waiting on rear wheel from bassets racing.  So I can start string lining gauging for. Rear sub Frame mounts.
                      IMG_1269.MP4
                      • IMG_1269.MP4
                        ThatRatRodProjectT
                        ThatRatRodProject
                        Sunday progress motor mounts done (wil have small pad between mounts. Next up is transmission mounts should be easy lots of room. Then to the rear subframe where heavy modifying will need to happen.
                        IMG_1275.MP4 IMG_1276.MP4 IMG_1277.MP4
                        • IMG_1275.MP4
                        • IMG_1276.MP4
                        • IMG_1277.MP4
