  4. TehRaydarlover's AWD lover
12v or dieixe30
156 Posts 15 Posters 3.2k Views 4 Watching
    Can I triple like that post!?!
      Jelly! When I go to Germany I'm bringing back a shipping crate haha, I'd snag that euro M5 interior in a heartbeat. Glad to see the IX back on the road too.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        I think I might order a revshift poly subframe, diff, and trailing arm bushing kit this weekend, 80a hardness... thoughts? I wonder if they could make me a transfer case bushing...
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          Power washed my engine bay and fried some relays :( been having some weird random rough idle and no start issues. Swapped in some spare e28 relays and it fixed the no start but I still get the occasional rough idle when I first start the car...
            Check the TPS
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              Damn! Good call! Went out and started it and when it started to stumble, I unplugged the TPS and it immediately shot back up to 900rmp. Can the TPS be adjusted or does it just need to be replaced? I do have a spare if needed.
                Protip: you learned the lesson on using powerwashers on engine bays, its a no no. Spraying hot water after soaking in degreaser (mean green or equivalent) is best unless you have access to a steam cleaner.
                  It can be adjusted but the tb has to come off (no big deal)
                  It is a three position switch, idle, part throttle, full throttle. So the switch can be checked for proper adjustment with a continuity tester
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    Pulled the tb off but one of the mounting screws for the tps is stripped. Kinda annoying.
                    • TehRaydarloverT
                      TehRaydarloverT
                      TehRaydarlover
                      Installed the spare TPS and it still doesn't want to idle correctly. :( when I unplug the TPS the rpms jump up to 900 where it should be. With it plugged in they are at around 6-700... makes me sad.
                        Idle control valve may be suspect then since the TPS signals the idle control valve to run.
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Forgot about the idle issue, it went away I think it just took some time for something to get dried out.. power washing engine bay - never again
                          Also someone at a car show I went to took this with a real camera.. I like!
                          Also thanks Andy for the new fog light! got it in just in time for the show :D
                            Which show was that at?
                              Mad Further: http://www.madfurther.com/
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                http://minneapolis.craigslist.org/hnp/pts/4639481413.html
                                Saw this add on craigslist and immediately jumped in the car. Let me know how I did, here's my haul:
                                s52 complete bottom end, exhaust manifolds w/o2 sensors, and valve cover- $250
                                i intake manifold - $20
                                hid kit - $10
                                m20 i head - $40
                                4 Dunlop Direzza Sport Z1 Star Spec - $60
                                Total investment - $380
                                By the time I got there the dash, race springs, e engine, 1 i engine and the seats were sold to people who paid him through paypal. lol cheaters I was the first one there :[
                                  Dang! Nice grabs. S52 bottom end for 3.0 m20 stroker???
                                  • TehRaydarloverT
                                    TehRaydarloverT
                                    TehRaydarlover
                                    maybe I already have a s52 crank for that haha, I kinda want to take the rods out of it but the BMW gods may forsaken me for disassembling a perfectly good bottom end just for the rods lol
                                    • TehRaydarloverT
                                      TehRaydarloverT
                                      TehRaydarlover
                                      lol I bought an m20 i head and s52 bottom end... s52 12 valve swap FTW!!!!!!
                                        If you don't want to use the bottom end I most certainly would :)
                                          I was just thinking of finding a set of those exhaust manifolds....
