686 Posts 32 Posters 8.9k Views 3 Watching
    Oreilly's rents out pickle forks and ball joint removers for free.  Just pay for it when you get it and get the full amount back when you return it.  That's about the only way to get them out.
      Pickle forks damage the ball joint boots very easily. Hit the ear on the hub that the ball joint goes through from the side with a BFH, should pop out.
        ^ This, only use a pickle fork if you are not planning to reuse the joints.
        • ClassEC
          ClassEC
          ClassE
          I called it a night at that point last night. I'll have a go at it again tonight after work.
          It's odd pulling this apart after working on VWs for so long - similar of course but not knowing the nut sizes off the top of my head and trying to "learn the car" makes it a slower process then I'm used to. Tonight is break the ball joint and tie tod ends loose and yank front suspension.... Then heading to rear.
          Tracking info shows rims are scheduled to arrive Friday..... I've got a lot of work to do to get the front coils welded up and toe/camber adjustments welded in Saturday and everything re-installed to test fit fitment.
          If Oshkosh area peeps are looking for something to do nights this week or Saturday afternoon I'd love the help!
            just on the topic of balljoint separators
            they have these at harbor freight (or for rent at o'reilly)
            best tool for ball joint separation.
            If you run into any snags with the rear subframe dont hesitate to PM/call.
            You should be able to manage, but it can be a little bit puzzling the first time if you dont "know the car"
            • ClassEC
              ClassEC
              ClassE
              Thanks Snap - I may take you up on that tonight if needed! Earl and John already had their footie pajamas on last night so they weren't a lot of help. :P
                hahahahaha. Any time before 8 feel free to call
                  ClassE said:
                  $400 ish from Condor - quality seems great. They should be in early next week - I'll report back once they're in!
                  Awesome, let us know!
                  • ClassEC
                    ClassEC
                    ClassE
                    This is the "loose wire" I found in the drivers well:
                      Yep brake pad wear sensor, that thing at the end clips into the little notch in the pad.  That one is probably junk, they need replacement when putting in new pads.
                        The sensor only needs to be replaced if it is worn through. As the pad gets thin, the sensor wears through, breaking the wire running through it, illuminating the light. Yours is most definitely junk by the looks of it.
                          Remove the wear sensors and pop the bulb out of the dash=) Save big money!
                            Or just connect the two wires...
                              Oh yeah....you told me to do that too. Looks like I found something to do Saturday=)
                              • ClassEC
                                ClassEC
                                ClassE
                                Fronts are out! Now on to the rear...
                                • ClassEC
                                  ClassEC
                                  ClassE
                                  My son Bennett thought he'd "help".
                                  • ClassEC
                                    ClassEC
                                    ClassE
                                    All I should have to do tomorrow to drop subframe is undo brake lines and unbolt subframe/diff bolt!
                                    I'm so happy with the underside of this car - I'm having a hard time finding any real "rust" of any kind (heck hardly any speckle rust or ugly anything!). Obviously filthy - but southern cars are definitely the way to go!!!
                                    Any help in ID'ing the existing drop springs - and a ballpark of what they're worth?
                                      Hmm...went back to look at pics of car height on first page...  If the price is right I might want them for my vert, I'd like a little drop but definitely not slammed.
                                        H&R sport
                                        • ClassEC
                                          ClassEC
                                          ClassE
                                          Fitment check. ;)
                                          Going to get hubs welded Saturday AM.
