  4. '88 E30
'88 E30
1.1k Posts 36 Posters 0 Views 1 Watching
    Only thing left to show up are the coils
    Pads/lines/CSB/diff plugs showed up today
    As well as this gem front Blunttech
    Also I lied, I have ate brake fluid&redline MTL showing up soon too. I was trolling craigslist in my area for shits and giggles and came across an ad for 2qts of redline 75w-90 and 2 gallons of BMW coolant. Guy wanted $50 for everything so I bought those as well-extra coolant isn't a bad thing to have on hand
    • JeffJ
      JeffJ
      Jeff
      That be a nice pile o parts rolls
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        Jerf is back!
        • JeffJ
          JeffJ
          Jeff
          Lol back again for a bit I hope time has not been permitting between work and home.
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            cock-and-ball bearing?
              Remember, if you preload the csb more than once its considered playing with your driveshaft
                What coils did you go with?
                  BC, 10k front 12k rear
                    Tricked myself into working on my car for 5 minutes
                    Got the DS back together with a new CSB. (Old one was installed incorrectly) -don't believe the Internet about installing the CSB "backwards" they are offset and put an angle on the DS at the CSB. I took a bunch of pics for the next thread I see about installing these backwards when using a 24v swap DS.
                    Also drained the old diff fluid
                    Went to put new drain plugs in. And I don't have an Allen wrench in size massive. So I need to go pick up a new wrench tomorrow so I can tighten it and put the redline 75w-90 in
                      Put a bolt in it and a nut on the bolt, then use a socket to tighten it
                        or
                        i go get the right size allen wrench
                          To be fair, earls idea is pretty slick and the next time there is a worldwide macho allen shortage I will try to remember it
                            It is a nifty idea. But I'm probably in the same boat as I don't have a bolt that exact size
                              So went to Sears and some other places. Nobody had an Allen that large. So I just bought a bolt and a few nuts. Gonna use the earl method.
                                A hex socket set would probably have the right size, you can buy the gear wrench set at Sears or Advance Auto.
                                  Looked for those as well. No luck.
                                  Bolt & nuts worked fine
                                  Fluids in and plugs are tioght
                                    I used a short bolt with a nut and welded them together. On the e36 you can't fit anything longer between the dif and spare tire well when in the car.
                                      New trans fluid is in. Went with redline MTL. also made a list which I immediately regretted. Pretty much ran out of cardboard.
                                        Patiently waiting for coilovers to show up........
                                          Coilovers are due to ship in about a week.
                                          In the meantime I've been looking at buying new wheels/rubber. I have it narrowed down to 15x8 so I can run the bfg rivals 205/50/15. They seem to run bigger. Pics of them on 8s actually look relatively square which I'm happy about. Or the hankook rs-3 in 225/45/15. Both will fit and be relatively square and cost pretty much the same .
                                          Trying to narrow down some wheels. They need to be 15x8, light, affordable and look okay. I'd also rather not run spacers but will if I have to
                                          So far:
                                          15x8
                                          14.6 lbs
                                          20mm offset
                                          $109 each
                                          15x8
                                          20mm offset
                                          13lbs
                                          $138 each
                                          15x8
                                          20mm offset
                                          13.5lbs
                                          $109 each
                                          Here's what the bfgs look like on 8s for example on the left dc22294ae529eda796649a31a2a41b4c.jpg
                                          I will be selling my 15x7 k1s
                                          I know they will probably work fine for me but I want something different and really want an 8" wheel for the future tire size changes
