  4. '88 E30
'88 E30
savebigmoney
    Tricked myself into working on my car for 5 minutes
    Got the DS back together with a new CSB. (Old one was installed incorrectly) -don't believe the Internet about installing the CSB "backwards" they are offset and put an angle on the DS at the CSB. I took a bunch of pics for the next thread I see about installing these backwards when using a 24v swap DS.
    Also drained the old diff fluid
    Went to put new drain plugs in. And I don't have an Allen wrench in size massive. So I need to go pick up a new wrench tomorrow so I can tighten it and put the redline 75w-90 in
      Put a bolt in it and a nut on the bolt, then use a socket to tighten it
        or
        i go get the right size allen wrench
          To be fair, earls idea is pretty slick and the next time there is a worldwide macho allen shortage I will try to remember it
            It is a nifty idea. But I'm probably in the same boat as I don't have a bolt that exact size
              So went to Sears and some other places. Nobody had an Allen that large. So I just bought a bolt and a few nuts. Gonna use the earl method.
                A hex socket set would probably have the right size, you can buy the gear wrench set at Sears or Advance Auto.
                  Looked for those as well. No luck.
                  Bolt & nuts worked fine
                  Fluids in and plugs are tioght
                    I used a short bolt with a nut and welded them together. On the e36 you can't fit anything longer between the dif and spare tire well when in the car.
                      New trans fluid is in. Went with redline MTL. also made a list which I immediately regretted. Pretty much ran out of cardboard.
                        Patiently waiting for coilovers to show up........
                          Coilovers are due to ship in about a week.
                          In the meantime I've been looking at buying new wheels/rubber. I have it narrowed down to 15x8 so I can run the bfg rivals 205/50/15. They seem to run bigger. Pics of them on 8s actually look relatively square which I'm happy about. Or the hankook rs-3 in 225/45/15. Both will fit and be relatively square and cost pretty much the same .
                          Trying to narrow down some wheels. They need to be 15x8, light, affordable and look okay. I'd also rather not run spacers but will if I have to
                          So far:
                          15x8
                          14.6 lbs
                          20mm offset
                          $109 each
                          15x8
                          20mm offset
                          13lbs
                          $138 each
                          15x8
                          20mm offset
                          13.5lbs
                          $109 each
                          Here's what the bfgs look like on 8s for example on the left dc22294ae529eda796649a31a2a41b4c.jpg
                          I will be selling my 15x7 k1s
                          I know they will probably work fine for me but I want something different and really want an 8" wheel for the future tire size changes
                            both those tires looked stretched to me....
                              That's why I said relatively square................................................
                                Tread width is 6.9" on a 205. 8" wheel. 100% not square, but relatively square compared to some of the crap that people run
                                This is why I'll probably go with a 225/45/15 rival. 7.9" tread width on an 8" wheel
                                  I do prefer a slight "stretch"
                                  I think the pictures above that you posted look fine to me.
                                  I run a 225/45/16 on a 16x8, getatmebro
                                  A friend has 225's on a 7" wheel and it looks a touch ballooned for my liking, for his car anyway.
                                  I like starting new lines for every sentence.
                                  Why do you live so far away
                                    The Kosei K8R are the clear winner for me. Other two are nice, but meh. I had K1s on my Miata and always wished they were wider. Debated buying those same C1s to replace them, but I'm glad I didn't. I love the way the K1s look.
                                    Both tires look stretched in that picture. I would definitely get the 225 at minimum.
                                      It's a toss up between the k5r and the k8r for me right now. 225 is for sure going on them
                                        Oops, I meant K8R, not the K5R.
                                        K8R is way better.
                                          I've been asking a bunch of people. K8r has been the consensus. I like the k8r simply because the k5r looks similar to what I already have
