  3. General Technical
  4. NA or Turbo
NA or Turbo
31 Posts 16 Posters 488 Views 1 Watching
  • 240sxguy2
    240sxguy2
    240sxguy
    teatoe993 said:
    I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of juvenile in my opinion. But I'm 34, so there you go.
    Sounds like fancy talk for slow. :)
    • Brian.B
      Brian.B
      Brian.
      This.
      Also, if you do decide to turbo it, don't do twin turbo, that's way to much work for no gain. Just do an single.
      instagram @howdoyoudrivethat
      • JeffJ
        JeffJ
        Jeff
        Brian said:
        This.
        There is gains for that extra work.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          Twin turbo is not a good idea. However, a compound turbo setup has many gains and advantages=)
          • Brian.B
            Brian.B
            Brian.
            Twin turboing a BMW M20 or even a 2jz, is kinda pointless, unless you go compound. But for a reliable dailyable car, I would not go twin. Just single it and call it a day.
            • JeffJ
              JeffJ
              Jeff
              A compund turbo set up is using 2 turbos
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                But they are used in sequence. It isn't a twin turbo setup.
                A twin turbo setup on a 2jz for example would have three exhaust ports feeding one turbo, and then three feeding another.
                On a compound turbo setup, they're used in sequence. You use a smaller turbo that spools fast to feed the large turbo to eliminate boost lag as much as possible=D
                • Brian.B
                  Brian.B
                  Brian.
                  but with an M20, there really isn't any turbo lag, unless you go with a HX40+ or the likes.
                  • JeffJ
                    JeffJ
                    Jeff
                    Very good point my sir
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      one of each is ideal, IMO.
                      • T
                        T
                        tsweers89
                        Just because you have a hx35 does not mean your not going to have lag. It depends on your tune and also the exhaust housing. If he had something like a 1.07 or even a .94 I bet there would be lag and wouldn't see boost till around 3.2k. Also looking at the compressor map for that it isnt in the efficiency range until around 19-22psi which would mean he probably need a built lower end. Also hx35 is a was outdated turbo technology wise. A t3 garret or borg warner would be leaps and bounds better especially for what he plans on using the vehicle for.
