  4. NA or Turbo
NA or Turbo
31 Posts 16 Posters 487 Views 1 Watching
  • teatoe993T
    teatoe993T
    teatoe993
    I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of juvenile in my opinion. But I'm 34, so there you go.
      does your display picture say "fart"
      :lol:
        Says the dude with a fart avatar. LOL
        • JeffJ
          JeffJ
          Jeff
          Vome drive my car and tell me you dont want turbo. And for the old farts it can help with gas mileage just dont run it hard. An tune for it.
          Twin turbo less lag!!!
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
          • 240sxguy2
            240sxguy2
            240sxguy
            Sounds like fancy talk for slow. :)
              This.
              Also, if you do decide to turbo it, don't do twin turbo, that's way to much work for no gain. Just do an single.
              • JeffJ
                JeffJ
                Jeff
                Brian said:
                This.
                There is gains for that extra work.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Twin turbo is not a good idea. However, a compound turbo setup has many gains and advantages=)
                    Twin turboing a BMW M20 or even a 2jz, is kinda pointless, unless you go compound. But for a reliable dailyable car, I would not go twin. Just single it and call it a day.
                    • JeffJ
                      JeffJ
                      Jeff
                      A compund turbo set up is using 2 turbos
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        But they are used in sequence. It isn't a twin turbo setup.
                        A twin turbo setup on a 2jz for example would have three exhaust ports feeding one turbo, and then three feeding another.
                        On a compound turbo setup, they're used in sequence. You use a smaller turbo that spools fast to feed the large turbo to eliminate boost lag as much as possible=D
                          but with an M20, there really isn't any turbo lag, unless you go with a HX40+ or the likes.
                          • JeffJ
                            JeffJ
                            Jeff
                            Very good point my sir
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              one of each is ideal, IMO.
                              • T
                                T
                                tsweers89
                                Just because you have a hx35 does not mean your not going to have lag. It depends on your tune and also the exhaust housing. If he had something like a 1.07 or even a .94 I bet there would be lag and wouldn't see boost till around 3.2k. Also looking at the compressor map for that it isnt in the efficiency range until around 19-22psi which would mean he probably need a built lower end. Also hx35 is a was outdated turbo technology wise. A t3 garret or borg warner would be leaps and bounds better especially for what he plans on using the vehicle for.
