<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NA or Turbo]]></title><description><![CDATA[<p dir="auto">Would you run a turbo on your car if you had the time/money/skills/balls</p>
<p dir="auto">Are you an NA snob like myself and prefer NA engines even though snails are the replacement for displacement? <br />
 </p>
<p dir="auto">state your point of view on snails.</p>
]]></description><link>https://wibimmers.com/topic/1510/na-or-turbo</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 06:49:37 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1510.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 May 2013 16:19:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NA or Turbo on Sun, 14 Jul 2013 15:33:33 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/24076">Brian said:</a></strong></p>
<p dir="auto">but with an M20, there really isn't any turbo lag, unless you go with a HX40+ or the likes.</p>
<p dir="auto">Just because you have a hx35 does not mean your not going to have lag. It depends on your tune and also the exhaust housing. If he had something like a 1.07 or even a .94 I bet there would be lag and wouldn't see boost till around 3.2k. Also looking at the compressor map for that it isnt in the efficiency range until around 19-22psi which would mean he probably need a built lower end. Also hx35 is a was outdated turbo technology wise. A t3 garret or borg warner would be leaps and bounds better especially for what he plans on using the vehicle for.</p>
]]></description><link>https://wibimmers.com/post/25424</link><guid isPermaLink="true">https://wibimmers.com/post/25424</guid><dc:creator><![CDATA[tsweers89]]></dc:creator><pubDate>Sun, 14 Jul 2013 15:33:33 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Sat, 13 Jul 2013 01:00:22 GMT]]></title><description><![CDATA[<p dir="auto">one of each is ideal, IMO.</p>
]]></description><link>https://wibimmers.com/post/25385</link><guid isPermaLink="true">https://wibimmers.com/post/25385</guid><dc:creator><![CDATA[The Full Banana]]></dc:creator><pubDate>Sat, 13 Jul 2013 01:00:22 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 17:51:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/24074">Earl said:</a></strong></p>
<p dir="auto">But they are used in sequence. It isn't a twin turbo setup.</p>
<p dir="auto">A twin turbo setup on a 2jz for example would have three exhaust ports feeding one turbo, and then three feeding another.</p>
<p dir="auto">On a compound turbo setup, they're used in sequence. You use a smaller turbo that spools fast to feed the large turbo to eliminate boost lag as much as possible=D</p>
<p dir="auto">Very good point my sir</p>
]]></description><link>https://wibimmers.com/post/24078</link><guid isPermaLink="true">https://wibimmers.com/post/24078</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 17:47:51 GMT]]></title><description><![CDATA[<p dir="auto">but with an M20, there really isn't any turbo lag, unless you go with a HX40+ or the likes.</p>
]]></description><link>https://wibimmers.com/post/24076</link><guid isPermaLink="true">https://wibimmers.com/post/24076</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:47:51 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 17:42:40 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/24067">Jeff said:</a></strong></p>
<p dir="auto">A compund turbo set up is using 2 turbos</p>
]]></description><link>https://wibimmers.com/post/24074</link><guid isPermaLink="true">https://wibimmers.com/post/24074</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:42:40 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 17:10:45 GMT]]></title><description><![CDATA[<p dir="auto">A compund turbo set up is using 2 turbos</p>
]]></description><link>https://wibimmers.com/post/24067</link><guid isPermaLink="true">https://wibimmers.com/post/24067</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 16:36:49 GMT]]></title><description><![CDATA[<p dir="auto">Twin turboing a BMW M20 or even a 2jz, is kinda pointless, unless you go compound. But for a reliable dailyable car, I would not go twin. Just single it and call it a day.</p>
]]></description><link>https://wibimmers.com/post/24062</link><guid isPermaLink="true">https://wibimmers.com/post/24062</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Thu, 13 Jun 2013 16:36:49 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 16:06:32 GMT]]></title><description><![CDATA[<p dir="auto">Twin turbo is not a good idea. However, a compound turbo setup has many gains and advantages=)</p>
]]></description><link>https://wibimmers.com/post/24059</link><guid isPermaLink="true">https://wibimmers.com/post/24059</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 13 Jun 2013 16:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 15:27:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/24053">Brian said:</a></strong></p>
<p dir="auto">This.</p>
<p dir="auto">Also, if you do decide to turbo it, don't do twin turbo, that's way to much work for no gain. Just do an single.</p>
<p dir="auto">There is gains for that extra work.</p>
]]></description><link>https://wibimmers.com/post/24055</link><guid isPermaLink="true">https://wibimmers.com/post/24055</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 13 Jun 2013 15:27:03 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 15:01:11 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/24049">240sxguy said:</a></strong></p>
<p dir="auto">Sounds like fancy talk for slow. <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/24053</link><guid isPermaLink="true">https://wibimmers.com/post/24053</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Thu, 13 Jun 2013 15:01:11 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 14:33:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/23513">teatoe993 said:</a></strong></p>
<p dir="auto">I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of juvenile in my opinion. But I'm 34, so there you go.</p>
]]></description><link>https://wibimmers.com/post/24049</link><guid isPermaLink="true">https://wibimmers.com/post/24049</guid><dc:creator><![CDATA[240sxguy]]></dc:creator><pubDate>Thu, 13 Jun 2013 14:33:42 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 13 Jun 2013 04:28:06 GMT]]></title><description><![CDATA[<p dir="auto">Vome drive my car and tell me you dont want turbo. And for the old farts it can help with gas mileage just dont run it hard. An tune for it.</p>
<p dir="auto">Twin turbo less lag!!!</p>
]]></description><link>https://wibimmers.com/post/24036</link><guid isPermaLink="true">https://wibimmers.com/post/24036</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 13 Jun 2013 04:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 17:32:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Says the dude with a fart avatar. LOL</p>
]]></description><link>https://wibimmers.com/post/23516</link><guid isPermaLink="true">https://wibimmers.com/post/23516</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 31 May 2013 17:32:28 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 16:51:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of <strong><em>juvenile</em></strong> in my opinion. But I'm 34, so there you go.</p>
<p dir="auto">does your display picture say "fart"  </p>
<p dir="auto"><img src="/assets/uploads/files/emoticons_default_laugh.png" alt=":lol:" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/23514</link><guid isPermaLink="true">https://wibimmers.com/post/23514</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 31 May 2013 16:51:57 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 16:42:24 GMT]]></title><description><![CDATA[<p dir="auto">I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of juvenile in my opinion. But I'm 34, so there you go.</p>
]]></description><link>https://wibimmers.com/post/23513</link><guid isPermaLink="true">https://wibimmers.com/post/23513</guid><dc:creator><![CDATA[teatoe993]]></dc:creator><pubDate>Fri, 31 May 2013 16:42:24 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 14:39:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/23413">Snap said:</a></strong></p>
<p dir="auto">If you decided to sell something with ball bearings id be busting down your front door with money in hand. </p>
<p dir="auto">Dude, 10psi at 3k rpm from an m10.... You would make immediate boost on an m20.</p>
<p dir="auto">Hybrid turbos for the win.</p>
<p dir="auto">Sent from the future. Or my phone, who knows.</p>
]]></description><link>https://wibimmers.com/post/23505</link><guid isPermaLink="true">https://wibimmers.com/post/23505</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Fri, 31 May 2013 14:39:15 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 03:04:55 GMT]]></title><description><![CDATA[<p dir="auto">N/A if you want to keep going slow, turbo if you wanna go fast.</p>
]]></description><link>https://wibimmers.com/post/23490</link><guid isPermaLink="true">https://wibimmers.com/post/23490</guid><dc:creator><![CDATA[damnboy037]]></dc:creator><pubDate>Fri, 31 May 2013 03:04:55 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Fri, 31 May 2013 02:28:44 GMT]]></title><description><![CDATA[<p dir="auto">You know my vote! <img src="/assets/uploads/files/emoticons_default_tongue.png" alt=":P" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/23485</link><guid isPermaLink="true">https://wibimmers.com/post/23485</guid><dc:creator><![CDATA[Bassboy3313]]></dc:creator><pubDate>Fri, 31 May 2013 02:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Thu, 30 May 2013 04:06:47 GMT]]></title><description><![CDATA[<p dir="auto">Boooooooooooooost!</p>
]]></description><link>https://wibimmers.com/post/23449</link><guid isPermaLink="true">https://wibimmers.com/post/23449</guid><dc:creator><![CDATA[patsbimmer1]]></dc:creator><pubDate>Thu, 30 May 2013 04:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Wed, 29 May 2013 23:01:51 GMT]]></title><description><![CDATA[<p dir="auto">turboturboturboturboturboturboturbo</p>
]]></description><link>https://wibimmers.com/post/23435</link><guid isPermaLink="true">https://wibimmers.com/post/23435</guid><dc:creator><![CDATA[lagwagon]]></dc:creator><pubDate>Wed, 29 May 2013 23:01:51 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Wed, 29 May 2013 15:49:13 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/23397">GunMetalGrey said:</a></strong></p>
<p dir="auto">Buy my shit, and then never have to look back and be sad! Sent from the future. Or my phone, who knows.</p>
<p dir="auto">Who'd you get your turbo setup from? Or did you piece it together? Only reason I ask is because someone up in the valley bought my buddies entire 2.7i turbo setup, and that thing was epic.</p>
]]></description><link>https://wibimmers.com/post/23414</link><guid isPermaLink="true">https://wibimmers.com/post/23414</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Wed, 29 May 2013 15:49:13 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Wed, 29 May 2013 15:47:59 GMT]]></title><description><![CDATA[<p dir="auto">If you decided to sell something with ball bearings id be busting down your front door with money in hand.</p>
]]></description><link>https://wibimmers.com/post/23413</link><guid isPermaLink="true">https://wibimmers.com/post/23413</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Wed, 29 May 2013 15:47:59 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Wed, 29 May 2013 04:26:15 GMT]]></title><description><![CDATA[<p dir="auto">Buy my shit, and then never have to look back and be sad!</p>
]]></description><link>https://wibimmers.com/post/23397</link><guid isPermaLink="true">https://wibimmers.com/post/23397</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 29 May 2013 04:26:15 GMT</pubDate></item><item><title><![CDATA[Reply to NA or Turbo on Tue, 28 May 2013 22:01:05 GMT]]></title><description><![CDATA[<p dir="auto">I will always vote for rage driving/drifting. So, I guess, whatever gives you the most rage driving/drifting experience/</p>
]]></description><link>https://wibimmers.com/post/23366</link><guid isPermaLink="true">https://wibimmers.com/post/23366</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Tue, 28 May 2013 22:01:05 GMT</pubDate></item></channel></rss>
