  4. NA or Turbo
NA or Turbo
31 Posts 16 Posters 487 Views 1 Watching
    You know my vote! :P
    • damnboy037D
      damnboy037D
      damnboy037
      N/A if you want to keep going slow, turbo if you wanna go fast.
      99 M3 320rwhp @ 6psi
      95 M3 s50b32
        If you decided to sell something with ball bearings id be busting down your front door with money in hand.
        Dude, 10psi at 3k rpm from an m10.... You would make immediate boost on an m20.
        Hybrid turbos for the win.
        • teatoe993T
          teatoe993T
          teatoe993
          I prefer to keep things simple and cheap. And I prefer a smooth torque-band. Turboing a car is kind of juvenile in my opinion. But I'm 34, so there you go.
            does your display picture say "fart"
            :lol:
              Says the dude with a fart avatar. LOL
              • JeffJ
                JeffJ
                Jeff
                Vome drive my car and tell me you dont want turbo. And for the old farts it can help with gas mileage just dont run it hard. An tune for it.
                Twin turbo less lag!!!
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                • 240sxguy2
                  240sxguy2
                  240sxguy
                  Sounds like fancy talk for slow. :)
                    This.
                    Also, if you do decide to turbo it, don't do twin turbo, that's way to much work for no gain. Just do an single.
                    • JeffJ
                      JeffJ
                      Jeff
                      Brian said:
                      This.
                      There is gains for that extra work.
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Twin turbo is not a good idea. However, a compound turbo setup has many gains and advantages=)
                          Twin turboing a BMW M20 or even a 2jz, is kinda pointless, unless you go compound. But for a reliable dailyable car, I would not go twin. Just single it and call it a day.
                          • JeffJ
                            JeffJ
                            Jeff
                            A compund turbo set up is using 2 turbos
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              But they are used in sequence. It isn't a twin turbo setup.
                              A twin turbo setup on a 2jz for example would have three exhaust ports feeding one turbo, and then three feeding another.
                              On a compound turbo setup, they're used in sequence. You use a smaller turbo that spools fast to feed the large turbo to eliminate boost lag as much as possible=D
                                but with an M20, there really isn't any turbo lag, unless you go with a HX40+ or the likes.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Very good point my sir
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    one of each is ideal, IMO.
                                    • T
                                      T
                                      tsweers89
                                      Just because you have a hx35 does not mean your not going to have lag. It depends on your tune and also the exhaust housing. If he had something like a 1.07 or even a .94 I bet there would be lag and wouldn't see boost till around 3.2k. Also looking at the compressor map for that it isnt in the efficiency range until around 19-22psi which would mean he probably need a built lower end. Also hx35 is a was outdated turbo technology wise. A t3 garret or borg warner would be leaps and bounds better especially for what he plans on using the vehicle for.
