pistonse30
    Making boss moves
      I did something.  Wrong end of the car but actually turned a bolt.
      2.93LSD $150 some bearing noise but it works!  I'm keeping the cover :)
      I'll hopefully get the 2.93LSD w/60% lock Wangman Diff in there today/this weekend.
        Are you not going to use a dual ear diff cover?
          ? What about your diff that you had built?
            I was sold an e36ti diff cover.........:mellow:
            I will probably add a reenforcement to the other side using the diff cover mounting holes as the diff mounting points.
              It's sitting in my garage in the box that it came in. Going to pop that in after I put the cover on and fill it with fluid.
                Between new tires and the diff im thinking you need to keep some pepto chewables in the car so peoples stomachs dont end up on the dashboard from that insane acceleration
                  I hope so!!!
                    Did some Diff stuff and cleaned the garage.
                    Like a Gilette commercial.
                    Took the board down the alley then put it to use.
                      Doorman
                      Looks like we've both been busy with diff work brother!!
                        Prepared the block with a sharpening stone.  I'm glad I pulled the trigger on adding this step.
                        Need to make that go in there.
                          Looks like you're running out of real estate in there.
                          GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT.
                          Monday was rough
                          • ClassEC
                            ClassEC
                            ClassE
                            Looks like you're running out of real estate in there. GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT. Monday was rough
                            IZ FUNNY CAUSE IZ REAL ESTATE JOKE!!!
                              I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks
                                DrLeadFoot said:
                                I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks Sent from my SM-G900V using Tapatalk
                                Those seem to be my famous last words
                                  Snap actually has voodoo dolls of you two and your cars. He breaks them so he can keep diagnosing your Megasquirt problems.
                                    • ClassEC
                                      ClassEC
                                      ClassE
                                      SnatchChat tells me you got more done today...
                                        A little progress was made. I'll update with pics tomorrow.
                                        - Head is torqued down to 35 ft/lbs. I'll recheck and go to 65 ft/lbs if they hold at 35 for the night.
                                        - Intake manifold is tapped and drilled for multi-port meth injection.
                                        - Mounted the distribution block and ran the 6 lines to the jet fittings.
                                        - Broke one jet from over tightening it. Sometimes I'd like not to learn anything new...
                                        - Picked up my diff cover and output shafts from Snap. I'm planning on getting the new diff in tomorrow morning.
                                          Quote of the decade right here
