pistonse30
    -Car on jack stands
    -Took Echo gas powered 191mph leaf blower and cleared underneath the car after removing oily cardboard
    -Move some other boxes around
    -Almost started doing the diff swap
    -Left garage
      DrLeadFoot said:
      -Car on jack stands
      -Left garage
      I was pretty sure this was a KaiserRolls post until I quadruple checked the username
        I'm getting my motivation though. Going back to basics, just go to the garage and chip away every day.
          Making boss moves
            I did something.  Wrong end of the car but actually turned a bolt.
            2.93LSD $150 some bearing noise but it works!  I'm keeping the cover :)
            I'll hopefully get the 2.93LSD w/60% lock Wangman Diff in there today/this weekend.
              Are you not going to use a dual ear diff cover?
                ? What about your diff that you had built?
                  I was sold an e36ti diff cover.........:mellow:
                  I will probably add a reenforcement to the other side using the diff cover mounting holes as the diff mounting points.
                    It's sitting in my garage in the box that it came in. Going to pop that in after I put the cover on and fill it with fluid.
                      Between new tires and the diff im thinking you need to keep some pepto chewables in the car so peoples stomachs dont end up on the dashboard from that insane acceleration
                        I hope so!!!
                          Did some Diff stuff and cleaned the garage.
                          Like a Gilette commercial.
                          Took the board down the alley then put it to use.
                            Doorman
                            Looks like we've both been busy with diff work brother!!
                              Prepared the block with a sharpening stone.  I'm glad I pulled the trigger on adding this step.
                              Need to make that go in there.
                                Looks like you're running out of real estate in there.
                                GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT.
                                Monday was rough
                                  Looks like you're running out of real estate in there. GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT. Monday was rough
                                  IZ FUNNY CAUSE IZ REAL ESTATE JOKE!!!
                                    I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks
                                      DrLeadFoot said:
                                      I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks Sent from my SM-G900V using Tapatalk
                                      Those seem to be my famous last words
                                        Snap actually has voodoo dolls of you two and your cars. He breaks them so he can keep diagnosing your Megasquirt problems.
