  4. chit chat thread
chit chat thread
  • JeffJ
    JeffJ
    Jeff
    I have had drill bits deflect about 3degrees without breaking (when drilling into an angle with no spot drill) tooling makes a difference. As for milling with a router table what I had found useful in routers and milling centers is setting up an air blast that point directly on the milling or drill bit to clear the chips. When machining on unstable work pieces or machines of will greatly benefit the job. Worst thing for tool life is double cutting chips and starts to bind in the flutes ( melty chips). Since you can't use a flood coolant on your router use air. A air gun from a compressor would work if you wanted to hold it. Also get coated end mills the will help tremendously with chips not clogging the flutes up.
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • JeffJ
      JeffJ
      Jeff
      Picked these up for the e38 this weekend9867904eb4ddbf00615153462a3b8ae7.jpg
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        randumb idea of the day:
        stereotypical "TOW" arrow sticker, except it says "WOT" and you stick it to your dash pointing at your gas pedal.
        I'd do it if the difference between WOT and driving like there's a cop following you was actually noticeable in my car.
          In order for it to be recognizable as pointing to the go pedal, I think it would be so low on the dash that only the person giving you road head would see it.
          Still a cool idea.....the sticker I mean.  We all know road head is a cool idea.
            http://bringatrailer.com/listing/1970-bmw-m2-1600-2-with-s14-m3-engine/
            I'm guessing it goes for $75,000
              That looks so good
                I love those steelies
                  ^ Agreed, they look awesome on there. Apparently they're off a MINI, but they look widened to me
                  • JeffJ
                    JeffJ
                    Jeff
                    Who is buying it?
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      Nevermind on the $75k, its from The Netherlands/not as exclusive as it would be here
                        Jeff said:
                        My wife showed me this today. Not sure who actually has a Facebook thing
                        https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
                        Hey I know that guy
                        • JeffJ
                          JeffJ
                          Jeff
                          Jeff said:
                          My wife showed me this today. Not sure who actually has a Facebook thing https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
                          Hey I know that guy
                          Interesting, where did you meet him?
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            Hey I know that guy
                            I wonder how I never saw that. That was funny as hell!..
                            How much did you pay if you dont mind me asking?
                              Jeff said:
                              Hey I know that guy
                              I've known him for 25 years
                                  Finally took some pictures of the test fixture that I built for work. Too bad my phone was being a potato.
                                  It's for testing a 6-up array of LED lighting boards. It's a basic functional test; just put 12v on it and make sure it lights up. Previously we were manually sticking meter leads in the connector on each board while holding a welding face mask over it so you didn't get blinded. This should be an improvement.
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    That's a pretty cool fixture. Looks like it would cut you test time in 3rds
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      So I bought an '04 Sienna van with a bad transmission.  It had been power flushed and that caused a plugged filter about 1000 miles later.  It was a good price due to being broken.  I towed it home and changed the filter and fluid, that got rid of the cavitating pump noise and it drives but the shifting is poor, harsh 1-2, weak 2-3, then 3-4-5 works ok.
                                      Last night I pulled the valve body to disassemble and clean it, I am going to try that first, if it still doesn't work I'm not out anything.  Most likely I will be hunting for a U151F transmission.
                                      I didn't get any pictures because my phone died but yikes there are a lot of small passages and valves in the valve body.  It's like black magic going on in there, several spools seemed sticky so I have a small amount of hope that it might solve my problems to clean it all carefully.
                                        I use the Castrol Transmax Multi-Import fluid in my 06. It made 0 difference in anything since it appeared to have been serviced recently before I bought it.
                                        Vacuuming out all the crackers and french fries was equally beneficial for shifting performance
                                          This is more like undriveable bad shifting.  The 06 and newer on has the same transmission but uses Toyota "WS" fluid rather than 04-05 uses "TI-V" the programming is different I think to match the lighter viscosity fluid.  I usually use Redline synthetic, the TI-V compatible fluid is their D4, they would recommend D6 for newer vehicles that require "WS" fluid.
                                          I will be adding some Lucas tranny doctor to this one for good luck...
                                          Fun fact, this '04 is an XLE Limited and has radar following cruise control, I doubt it works anymore but I did not know the was an option so long ago.
