  4. chit chat thread
chit chat thread
    http://bringatrailer.com/listing/1970-bmw-m2-1600-2-with-s14-m3-engine/
    I'm guessing it goes for $75,000
    That looks so good
      I love those steelies
        ^ Agreed, they look awesome on there. Apparently they're off a MINI, but they look widened to me
        • JeffJ
          JeffJ
          Jeff
          Who is buying it?
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            Nevermind on the $75k, its from The Netherlands/not as exclusive as it would be here
              Jeff said:
              My wife showed me this today. Not sure who actually has a Facebook thing
              https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
              Hey I know that guy
              • JeffJ
                JeffJ
                Jeff
                Jeff said:
                My wife showed me this today. Not sure who actually has a Facebook thing https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
                Hey I know that guy
                Interesting, where did you meet him?
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Hey I know that guy
                  I wonder how I never saw that. That was funny as hell!..
                  Jeff said:
                  Picked these up for the e38 this weekend9867904eb4ddbf00615153462a3b8ae7.jpg
                  How much did you pay if you dont mind me asking?
                    Jeff said:
                    Hey I know that guy
                    I've known him for 25 years
                        Finally took some pictures of the test fixture that I built for work. Too bad my phone was being a potato.
                        It's for testing a 6-up array of LED lighting boards. It's a basic functional test; just put 12v on it and make sure it lights up. Previously we were manually sticking meter leads in the connector on each board while holding a welding face mask over it so you didn't get blinded. This should be an improvement.
                        • JeffJ
                          JeffJ
                          Jeff
                          That's a pretty cool fixture. Looks like it would cut you test time in 3rds
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            So I bought an '04 Sienna van with a bad transmission.  It had been power flushed and that caused a plugged filter about 1000 miles later.  It was a good price due to being broken.  I towed it home and changed the filter and fluid, that got rid of the cavitating pump noise and it drives but the shifting is poor, harsh 1-2, weak 2-3, then 3-4-5 works ok.
                            Last night I pulled the valve body to disassemble and clean it, I am going to try that first, if it still doesn't work I'm not out anything.  Most likely I will be hunting for a U151F transmission.
                            I didn't get any pictures because my phone died but yikes there are a lot of small passages and valves in the valve body.  It's like black magic going on in there, several spools seemed sticky so I have a small amount of hope that it might solve my problems to clean it all carefully.
                              I use the Castrol Transmax Multi-Import fluid in my 06. It made 0 difference in anything since it appeared to have been serviced recently before I bought it.
                              Vacuuming out all the crackers and french fries was equally beneficial for shifting performance
                                This is more like undriveable bad shifting.  The 06 and newer on has the same transmission but uses Toyota "WS" fluid rather than 04-05 uses "TI-V" the programming is different I think to match the lighter viscosity fluid.  I usually use Redline synthetic, the TI-V compatible fluid is their D4, they would recommend D6 for newer vehicles that require "WS" fluid.
                                I will be adding some Lucas tranny doctor to this one for good luck...
                                Fun fact, this '04 is an XLE Limited and has radar following cruise control, I doubt it works anymore but I did not know the was an option so long ago.
                                • GB-335xiCoupeG
                                  GB-335xiCoupeG
                                  GB-335xiCoupe
                                  In 2004 they had adaptive cruise control, but it was $$$ option. Getting to be standard equip nowadays...
                                  I'm almost 100% sure you'll be looking for a new tranny.
                                  How many miles on it?
                                    172k.  I'm sure it's toast but I like taking stuff apart and i'm not out anything but an evenings work if it still doesn't work.
                                    • GB-335xiCoupeG
                                      GB-335xiCoupeG
                                      GB-335xiCoupe
                                      It is definitely fun taking stuff apart. Like when I changed the starter motor in my 335. What a PITA!  I curse that one bolt in the back of the motor! Three inches from the firewall. WTF, BMW?!?! But I got it all back together and believe it or not, it works!
                                        A flex head wrench is the key there.
                                        • GB-335xiCoupeG
                                          GB-335xiCoupeG
                                          GB-335xiCoupe
                                          Ya! I found that out later. Plus the universal size for that F... er.. what I meant to say - FINE E-torx - I just bought a set of ratcheting ones from Sears and they are very nice.
