  4. chit chat thread
chit chat thread
  • JeffJ
    JeffJ
    Jeff
    Picked these up for the e38 this weekend9867904eb4ddbf00615153462a3b8ae7.jpg
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      randumb idea of the day:
      stereotypical "TOW" arrow sticker, except it says "WOT" and you stick it to your dash pointing at your gas pedal.
      I'd do it if the difference between WOT and driving like there's a cop following you was actually noticeable in my car.
        In order for it to be recognizable as pointing to the go pedal, I think it would be so low on the dash that only the person giving you road head would see it.
        Still a cool idea.....the sticker I mean.  We all know road head is a cool idea.
          http://bringatrailer.com/listing/1970-bmw-m2-1600-2-with-s14-m3-engine/
          I'm guessing it goes for $75,000
            That looks so good
              I love those steelies
                ^ Agreed, they look awesome on there. Apparently they're off a MINI, but they look widened to me
                • JeffJ
                  JeffJ
                  Jeff
                  Who is buying it?
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    Nevermind on the $75k, its from The Netherlands/not as exclusive as it would be here
                      Jeff said:
                      My wife showed me this today. Not sure who actually has a Facebook thing
                      https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
                      Hey I know that guy
                      • JeffJ
                        JeffJ
                        Jeff
                        Jeff said:
                        My wife showed me this today. Not sure who actually has a Facebook thing https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
                        Hey I know that guy
                        Interesting, where did you meet him?
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Hey I know that guy
                          I wonder how I never saw that. That was funny as hell!..
                          How much did you pay if you dont mind me asking?
                            Jeff said:
                            Hey I know that guy
                            I've known him for 25 years
                                Finally took some pictures of the test fixture that I built for work. Too bad my phone was being a potato.
                                It's for testing a 6-up array of LED lighting boards. It's a basic functional test; just put 12v on it and make sure it lights up. Previously we were manually sticking meter leads in the connector on each board while holding a welding face mask over it so you didn't get blinded. This should be an improvement.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  That's a pretty cool fixture. Looks like it would cut you test time in 3rds
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    So I bought an '04 Sienna van with a bad transmission.  It had been power flushed and that caused a plugged filter about 1000 miles later.  It was a good price due to being broken.  I towed it home and changed the filter and fluid, that got rid of the cavitating pump noise and it drives but the shifting is poor, harsh 1-2, weak 2-3, then 3-4-5 works ok.
                                    Last night I pulled the valve body to disassemble and clean it, I am going to try that first, if it still doesn't work I'm not out anything.  Most likely I will be hunting for a U151F transmission.
                                    I didn't get any pictures because my phone died but yikes there are a lot of small passages and valves in the valve body.  It's like black magic going on in there, several spools seemed sticky so I have a small amount of hope that it might solve my problems to clean it all carefully.
                                      I use the Castrol Transmax Multi-Import fluid in my 06. It made 0 difference in anything since it appeared to have been serviced recently before I bought it.
                                      Vacuuming out all the crackers and french fries was equally beneficial for shifting performance
                                        This is more like undriveable bad shifting.  The 06 and newer on has the same transmission but uses Toyota "WS" fluid rather than 04-05 uses "TI-V" the programming is different I think to match the lighter viscosity fluid.  I usually use Redline synthetic, the TI-V compatible fluid is their D4, they would recommend D6 for newer vehicles that require "WS" fluid.
                                        I will be adding some Lucas tranny doctor to this one for good luck...
                                        Fun fact, this '04 is an XLE Limited and has radar following cruise control, I doubt it works anymore but I did not know the was an option so long ago.
                                        • GB-335xiCoupeG
                                          GB-335xiCoupeG
                                          GB-335xiCoupe
                                          In 2004 they had adaptive cruise control, but it was $$$ option. Getting to be standard equip nowadays...
                                          I'm almost 100% sure you'll be looking for a new tranny.
                                          How many miles on it?
