chit chat thread
I have had drill bits deflect about 3degrees without breaking (when drilling into an angle with no spot drill) tooling makes a difference. As for milling with a router table what I had found useful in routers and milling centers is setting up an air blast that point directly on the milling or drill bit to clear the chips. When machining on unstable work pieces or machines of will greatly benefit the job. Worst thing for tool life is double cutting chips and starts to bind in the flutes ( melty chips). Since you can't use a flood coolant on your router use air. A air gun from a compressor would work if you wanted to hold it. Also get coated end mills the will help tremendously with chips not clogging the flutes up.
http://bringatrailer.com/listing/1970-bmw-m2-1600-2-with-s14-m3-engine/
I'm guessing it goes for $75,000
That looks so good
My wife showed me this today. Not sure who actually has a Facebook thing
https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
Hey I know that guy
Jeff said:
My wife showed me this today. Not sure who actually has a Facebook thing https://m.facebook.com/SKYLINESthelimit/posts/683884955155750
Hey I know that guy
Interesting, where did you meet him?
Hey I know that guy
I wonder how I never saw that. That was funny as hell!..
How much did you pay if you dont mind me asking?
Hey I know that guy
I've known him for 25 years
Finally took some pictures of the test fixture that I built for work. Too bad my phone was being a potato.
It's for testing a 6-up array of LED lighting boards. It's a basic functional test; just put 12v on it and make sure it lights up. Previously we were manually sticking meter leads in the connector on each board while holding a welding face mask over it so you didn't get blinded. This should be an improvement.
So I bought an '04 Sienna van with a bad transmission. It had been power flushed and that caused a plugged filter about 1000 miles later. It was a good price due to being broken. I towed it home and changed the filter and fluid, that got rid of the cavitating pump noise and it drives but the shifting is poor, harsh 1-2, weak 2-3, then 3-4-5 works ok.
Last night I pulled the valve body to disassemble and clean it, I am going to try that first, if it still doesn't work I'm not out anything. Most likely I will be hunting for a U151F transmission.
I didn't get any pictures because my phone died but yikes there are a lot of small passages and valves in the valve body. It's like black magic going on in there, several spools seemed sticky so I have a small amount of hope that it might solve my problems to clean it all carefully.
This is more like undriveable bad shifting. The 06 and newer on has the same transmission but uses Toyota "WS" fluid rather than 04-05 uses "TI-V" the programming is different I think to match the lighter viscosity fluid. I usually use Redline synthetic, the TI-V compatible fluid is their D4, they would recommend D6 for newer vehicles that require "WS" fluid.
I will be adding some Lucas tranny doctor to this one for good luck...
Fun fact, this '04 is an XLE Limited and has radar following cruise control, I doubt it works anymore but I did not know the was an option so long ago.
