Non-BMW Stuff on a BMW Forum
    Question time. Working on the power steering. Got a rebuild kit from FCP for the pump. Didn't know there were 2 kinds of pumps: ZF and Vickers. I have a Vickers. So naturally the rebuild kit for a ZF pump didn't work with my pump.
    What's the difference between the two? I  think I'll just order a clean pump off Ebay, but will a ZF pump use the same brackets and everything as a Vickers?
      Thats a really good question!
      Sadly the internet says you'll have to buy the two brackets to convert it to a ZF.
      The internet also says ZF is the way to go and easier to find parts for.
        I ended up ordering a Vickers rebuild kit from the dealer. Supposedly only 3 of them left in the US.
        Tonight I got the rest of the shifter back together and the new knob in. While going through the gears I feel like the shift from 2nd to 3rd is a lot shorter than the shift from 4th to 5th. Less moving the shifter sideways if that makes sense. Is that normal? These transmissions are new to me, so I'm not entirely sure what they're "supposed" to feel like.
          Yup, that's normal! I only had a car with a g260 for a few months, but every manual BMW I've ever driven has a detent on 5th gear (similar to reverse, but not as hard to overcome) and the shift is a lot further over.
            That's exactly what it feels like. Huh. I assume because it's a cruising gear that they put 1-4 closer together.
            That's interesting though.
              An update, but not on the e30. Sold the S60R this past weekend. Wanted something with better fuel economy and more space. Couldn't find any Volvo wagons locally in decent shape so I picked this up.
              Really happy with it so far. Needs a couple things: heater valve, windshield cowl and rear right window regulator to start. Then tires and some from suspension stuff.
                Are those the depo smoked headlights?
                  On the e30?
                    Nice scoop!!! I am on the hunt for a nice wagon myself. Is it auto or manual?
                      Thank you. It's auto. Base model. Which is all fine. Daily duty and family car, so auto is easier.
                        gilber33 said:
                        On the e30?
                        Yes, the Depo smoked smileys with the cross hairs. I was looking at purchasing them but wanted to know what the wiring process was like.
                          I don't think they're depo. They were on the car when I go it.
                            I have Depo and they are the same plugs as any OEM euro lights. The wiring is easy. The connectors Depo supplies for the headlights lights are only half of what you need, you'll want to get some OEM headlight plugs for euro spec lights. The connectors they supply for the city lights are sufficient for tapping into your side markers.
                            Its the same as swapping to euro headlights. You can search on the internet and find write-ups.  This DIY is quick to the point: http://www.rtsauto.com/e30-euro-smiley-conversion-from-sealed-beams-or-us-ellipsoids/
                              I will be contacting you in the future with any other questions. Thank you.
                                Confirmed they are Depo.
                                Question: tonight I started putting the power steering stuff back together. And I cannot remember how all the brackets worked on the pump. Can someone tell me if this looks right? It doesnt feel right and I don't see how it would allow for the tensioner to even work.
                                  Nevermind. I looked at my pictures more and the PS pump is on there correct. I didn't feel right at the time, but I see now how it is.
                                    Welcome to multiple bmw ownership, it’s a slippery slope. 😂
                                      Fixed a few things on the e46: window regulator, windshield cowl, and new heater control valve. Someone at some point bypasses the heater valve and the AC was pretty weak.
                                      I was also in Malibu this past weekend for a friends wedding and got to drive a couple of his cars as well as a friend's S52 swapped E30 in the canyons. It was an absolute blast and gave me renewed motivation to get my e30 done.
                                        Did you get to drive that 993? 😍
                                          I was lucky enough to drive all of them up and down a couple times. It was an experience I will never forget.
