  4. Lifted E30 V2
Lifted E30 V2
    Cool shit. You embedded the same video twice, FYI.
      This is going to be awesome
        Woah! Glad you got it to kick over and run. This is going to kick ass!
          Well either Flickr is being dumb or my connection here is mediocre. Not sure which one.
          Ordered a rebuild kit for the stock turbo, going to just rebuild that one.
            Okay, this is getting annoying. The links pull the video in then when I post it just goes white.
              Same thing happened here.
                Not sure what happened but now all the videos are gone. Flickr is great for photos, I've never relied on them for video. Try YouTube.
                  Simplicity is king
                      Tore the stock turbo apart last night and replaced the bearings, as the old ones were absolutely terrible.
                      The compressor wheel did indeed rub the housing a bit, but for now it's whatever. I grabbed a generic T3 rebuild kit from ebay for $30 and it worked perfectly.
                      I didn't take a ton of pictures
                      After I got the CHRA all stripped down
                      The edge of this guy was a bit concerning, as the compressor housing had similar markings, but we shall see if it was detrimental!
                      I wish someone else was around to see it, but as you can see by the mangled snap ring I got a bit annoyed with it and ended up using a screwdriver to push the edge in until it shot out of the housing. It flew up and hit the wall probably 10 feet up, and then I heard it land in the plastic tray with all of the new parts. I quick glanced for it and didn't see it. When I went to grab a new snap ring I saw the bent and oily one sitting in with all of the others. It flew right into its proper spot in the tray!
                      New bearings in, with new snap rings.
                      All together!
                      I pumped some oil into it to see how it felt, and it has no perceivable shaft play, and spun fairly well. I'm sure once it gets spun by the exhaust for awhile it will wear in a touch and free up a little bit, but even if it doesn't change it is a large improvement over what it had been.
                      Next step, time the motor and fuel pump!
                        nice work! did the new bearing press in easily?
                        Do you put a little silicone on the compressor housing when you install it?
                          The new bearings slid in quite nicely.
                          I started doing that with the HX35, and planned on doing the same for this one, yes.
                            Make sure you get that thing properly balanced especially after the wheel has been rubbing on the housing. I'm rebuilding a turbo for my saabaru at the moment and forgot to mark te CHRA in relation to the wheels. I sent it in to get balanced and they said it was good I did since it was way out of balance. Just some food for thought.
                              I marked out the wheel to the shaft and the nut. It's all lined back up.
                              Do I think it's perfect? No
                              Am I going to spend the money getting a turbo that rubbed balanced? Not thinking so
                              There is a couple of turbo's for the motor on ebay so if I need one down the road I can grab one, or go with something slightly larger.
                                Some throwback pics as I browse through Flickr
                                IMG20160501163845628HDR
                                Pictures make me miss the 325, reality makes me not miss it.
                                IMG20160202155631649HDR
                                126969251020630282299300141349278473756547o
                                2016-10-1101-18-33
                                12710751102063028220729782790544682305896064o
                                This concludes photo dumps, with Ben
                                  Also congrats on following through
                                    And to top it off, it appears (from my research) that I actually have a Euro M21, as it does not have any electronics other than a fuel solenoid that need to be connected to run it. Guess that was a euro only thing?
                                      Got some stoof done this weekend!
                                      Converted the fuel system from feeding fuel to feeding diesel.
                                      I took the foam out of the bottom of the fuel cell, time will tell if that was a good move or not.
                                      There was a surprising amount of crap in the bottom of the cell, including some sort of mfg. leftovers!
                                      I enjoy the color of diesel
                                      Took out the fuel pump and such from the trunk, and it leaves me with a comically small amount of stuff.
                                      The weird part to me at this point is that there is no fuel pressure in any of the chassis lines anymore, only in the injector hard lines. It makes my life easier for sure!
                                      I re-timed the motor and fuel pump as I noticed when switching the timing belt that the crank was not at tdc when everything else was. Brett suggested leaving it that way for the first startup due to potential pump timing issues, and I cleaned up all timing elements.
                                      This is how you read the engine timing.
                                      It threads into the back of the pump, and you rotate the motor until you get the highest reading, zero the dial indicator, rotate to tdc again and measure the offset. The timing was a touch too aggressive so I brought it down a little bit, to what most people use as performance timing for the motor.
                                      Sadly the cam isn't in great shape, quite scored where it rides.
                                      I find the vacuum pump kind of cool, as it bolts up to the cam and rides on an extra lobe.
                                      A overall shot for you m20 guys.
                                      Also found that the starter and flywheel were not playing nice together!
                                      IMG20171201203022IMG20171201203011
                                      There was a lot of metal shavings on the bottom of the bell housing, but it looks like the problem resolved itself so I may just go with it.
                                      Starter doesn't show signs of wear.
                                      I guess I didn't take a picture, but I got the motor back in the car and have it all bolted up.
                                        Nice work, excited to see this beast rolling coal!
                                          strange how the M20  didnt come with bearing caps but the M21 did. I enjoy seeing the guts of this thing though, its so different than what most of us are used to
