New ride
Whoa now! Put the brakes on the water/meth! You don't even have a tune yet and you're worried about meth? Go fbo and worry about meth later. MHD does literally just about everything that jb4 does except 2-step which you don't need unless you're drag racing, gauge hijacking/sweeping which loses it's cool factor quickly and meth control which you don't need until you max out your injectors and you're far from that. You could even get an external meth controller if you really wanted.
Flash the car, add some parts, do another flash. Jb4+MHD is great for maxing out the car but you're not even close to being there yet. Enjoy the power gains incrementally while you learn how to drive it.
Those were three of the differentiators I pointed out
As you can tell, Pat seems to be an MHD guy and I'm a JB4 guy. I run both and the car always ran PERFECT on stock turbos. I don't think you can go wrong with either, but JB4 has more benefits in my mind. If you want meth at some point, get JB4. It even integrates with port injection so you don't have to run a secondary controller.
PS: Your injectors won't max out. It's the HPFP and LPFP that can't keep up. These direct injectors can supply fuel for days.
I'm not that interested in the huge power gains from it, its more something I was looking into for the cooling. There isn't any real downside to it after the install so I figure why not, it sets the car up nicely for later. I started looking into E85 a little but that sounds like a bigger pain.
I could be barking up the wrong tree here, but heat kills everything so it sounds like a relatively good way to keep things a lot cooler. I just wasn't sure how the tunes play with it.I really want to invest in parts in an order that will keep things from blowing up on me.
I agree with Pat that meth wouldn't be my first mod, but it definitely benefits to cool things down. I'm thinking about adding it now with my current build, but need a new motor first. It never hurts to keep things cooler, but I'd get bolt ons and a tune first. If you have E85 in your area, it's worth mixing. JB4 even has an auto-tuning map that will give you the best performance for your current fuel and temperature conditions
There is nothing wrong with meth injection on a stock car. You can just use water injection at first for cooling. If you run out of injector, meth would be a risky solution if you are running an off the shelf kit. The shurflo pumps don't last very long, and if you run out and do a hard pull things can happen. Meth injection is going to give you the benefit of running high octane fuel with out the 7 dollar a gallon price.
Opinions on muffler delete? I want to do exhaust work eventually but just want more volume for now, everything online is mixed between sounds great and drone.
"Golf tee mod" first
Sounds like shit. Golf tee mod is a good start and a PE mod muffler with dp's is better.
I didn't know that golf tee mod was a thing, I'll do that tonight and see how it sounds. I really just want volume for now and I'm not sure when I'll have a chance to put downpipes on.
Downpipes help open it up and add volume but even without them the PE mod mufflers sound way nicer than hacking the muffler off.
@jc43089 the n55 sounds a lot nicer than the n54 and you can correct me if you know otherwise but I believe the f32 doesn't have resonator's where the f30 does. It's the same in the e90/e92. Sedans have resonators.
PE Mod is removing all the stuff inside the mufflers, isn't it? I don't have that sort of equipment
Not exactly "removing all the stuff" but removing the perforated pipe inside the muffler and welding in a solid piece. For a couple hundred bucks you can get it done by an exhaust shop. Just please, for the love of all that is decent, don't cut the mufflers off.
Looks like PO already did the PE mod. And I'll take your word on the mufflers and leave them alone lol, I have lots to learn about modding this thing and advice is one of the reasons I come here.
Case and point, your first suggestion just arrived today. I'll take it for a spin tomorrow to try it out since my car cover disappeared somehow anyway, I'll need a new one to keep birds away...
Hmm, that is quite possible, now that you mention it I don't think there was any resonator.
Nice! The ZHP knob is awesome!
Good to get baseline #s before doing upgrades.
I feel good about these numbers and the graph itself looks healthy. There was an mr2 on before me and his graph was a mess, like it was missing or not getting good ignition.
Anyways, up we go
Upgrade & slap it on a dynojet.
In4gainz
