  4. New ride
New ride
162 Posts 20 Posters 3.0k Views 1 Watching
  • IceddragonI
    IceddragonI
    Iceddragon
    Experienced a couple of firsts in the car this weekend.
    Heard my first wastegate rattle while leaving the hotel, which I'm assuming stemmed from not letting things cool off properly after beating on it a little. It never came back the rest of the weekend but at least I know what it sounds like now.
    I also did my first race. A friend of mine owns an 07 300 SRT8 and we've been talking about running it against whatever I buy for a while now, so that finally happened. I should have beat him in a 20 roll but I hesitated going into third, just inexperience on my part. We both agree that I should have won with a better driver, but I'm extremely impressed that it performed that well. I'm still completely stock so he has at least 100 hp on me...
      I saw your car at the show this weekend I was going to leave a wibimmers sticker but dumbass me left it at home.
      • IceddragonI
        IceddragonI
        Iceddragon
        haha, I'll get one at the october cruise
          Wastegate rattle won't have anything to do with you not letting things cool off. However, wastegate rattle is most prominent on cold starts.
          Get JB4 or MHD, you'll thank me later.
            2nd that. It is a cold start issue but not necesaarily heat dependant.  Get MHD.  The car is going to break eventually so you might as well have fun before hand.
            • IceddragonI
              IceddragonI
              Iceddragon
              Stop telling me its going to break, that ruins it!
              MHD is coming first, is that compatible with a water/meth kit though? I thought JB4 and cobb specifically have maps for running those but I don't know if MHD does as well.
                To my knowledge, JB4 is the only one that can trigger water/meth. I love my JB4 and would highly recommend it to anyone, even if you don't want more power. It allows you to monitor tons of variables, scan for codes, delete codes, and comes with some cool features (gauge hijacking, sweeping, wastegate control, 2-step, etc.)
                  Whoa now!  Put the brakes on the water/meth!  You don't even have a tune yet and you're worried about meth?  Go fbo and worry about meth later.  MHD does literally just about everything that jb4 does except 2-step which you don't need unless you're drag racing, gauge hijacking/sweeping which loses it's cool factor quickly and meth control which you don't need until you max out your injectors and you're far from that.  You could even get an external meth controller if you really wanted.
                  Flash the car, add some parts, do another flash.  Jb4+MHD is great for maxing out the car but you're not even close to being there yet.  Enjoy the power gains incrementally while you learn how to drive it.
                  • IceddragonI
                    IceddragonI
                    Iceddragon
                    I'm not that interested in the huge power gains from it, its more something I was looking into for the cooling. There isn't any real downside to it after the install so I figure why not, it sets the car up nicely for later. I started looking into E85 a little but that sounds like a bigger pain.
                    I could be barking up the wrong tree here, but heat kills everything so it sounds like a relatively good way to keep things a lot cooler. I just wasn't sure how the tunes play with it.I really want to invest in parts in an order that will keep things from blowing up on me.
                      Those were three of the differentiators I pointed out 😆
                      As you can tell, Pat seems to be an MHD guy and I'm a JB4 guy. I run both and the car always ran PERFECT on stock turbos. I don't think you can go wrong with either, but JB4 has more benefits in my mind. If you want meth at some point, get JB4. It even integrates with port injection so you don't have to run a secondary controller.
                      PS: Your injectors won't max out. It's the HPFP and LPFP that can't keep up. These direct injectors can supply fuel for days.
                      I agree with Pat that meth wouldn't be my first mod, but it definitely benefits to cool things down. I'm thinking about adding it now with my current build, but need a new motor first. It never hurts to keep things cooler, but I'd get bolt ons and a tune first. If you have E85 in your area, it's worth mixing. JB4 even has an auto-tuning map that will give you the best performance for your current fuel and temperature conditions 😉
                        There is nothing wrong with meth injection on a stock car. You can just use water injection at first for cooling. If you run out of injector, meth would be a risky solution if you are running an off the shelf kit. The shurflo pumps don't last very long, and if you run out and do a hard pull things can happen. Meth injection is going to give you the benefit of running high octane fuel with out the 7 dollar a gallon price.
                        • IceddragonI
                          IceddragonI
                          Iceddragon
                          Opinions on muffler delete? I want to do exhaust work eventually but just want more volume for now, everything online is mixed between sounds great and drone.
                            "Golf tee mod" first
                            http://www.e90post.com/forums/showthread.php?t=80661
                              Sounds like shit.  Golf tee mod is a good start and a PE mod muffler with dp's is better.
                                I installed a downpipe on an f32 N55 which I think already had the PE exhaust the sound was awesome.
                                • IceddragonI
                                  IceddragonI
                                  Iceddragon
                                  I didn't know that golf tee mod was a thing, I'll do that tonight and see how it sounds. I really just want volume for now and I'm not sure when I'll have a chance to put downpipes on.
                                    Downpipes help open it up and add volume but even without them the PE mod mufflers sound way nicer than hacking the muffler off.
                                      @jc43089 the n55 sounds a lot nicer than the n54 and you can correct me if you know otherwise but I believe the f32 doesn't have resonator's where the f30 does.  It's the same in the e90/e92.  Sedans have resonators.
                                      • IceddragonI
                                        IceddragonI
                                        Iceddragon
                                        PE Mod is removing all the stuff inside the mufflers, isn't it? I don't have that sort of equipment
                                          Not exactly "removing all the stuff" but removing the perforated pipe inside the muffler and welding in a solid piece.  For a couple hundred bucks you can get it done by an exhaust shop.  Just please, for the love of all that is decent, don't cut the mufflers off.
