  4. New ride
New ride
162 Posts 20 Posters 3.0k Views 1 Watching
    There is nothing wrong with meth injection on a stock car. You can just use water injection at first for cooling. If you run out of injector, meth would be a risky solution if you are running an off the shelf kit. The shurflo pumps don't last very long, and if you run out and do a hard pull things can happen. Meth injection is going to give you the benefit of running high octane fuel with out the 7 dollar a gallon price.
    • IceddragonI
      IceddragonI
      Iceddragon
      Opinions on muffler delete? I want to do exhaust work eventually but just want more volume for now, everything online is mixed between sounds great and drone.
        "Golf tee mod" first
        http://www.e90post.com/forums/showthread.php?t=80661
          Sounds like shit.  Golf tee mod is a good start and a PE mod muffler with dp's is better.
            I installed a downpipe on an f32 N55 which I think already had the PE exhaust the sound was awesome.
            • IceddragonI
              IceddragonI
              Iceddragon
              I didn't know that golf tee mod was a thing, I'll do that tonight and see how it sounds. I really just want volume for now and I'm not sure when I'll have a chance to put downpipes on.
                Downpipes help open it up and add volume but even without them the PE mod mufflers sound way nicer than hacking the muffler off.
                  @jc43089 the n55 sounds a lot nicer than the n54 and you can correct me if you know otherwise but I believe the f32 doesn't have resonator's where the f30 does.  It's the same in the e90/e92.  Sedans have resonators.
                  • IceddragonI
                    IceddragonI
                    Iceddragon
                    PE Mod is removing all the stuff inside the mufflers, isn't it? I don't have that sort of equipment
                      Not exactly "removing all the stuff" but removing the perforated pipe inside the muffler and welding in a solid piece.  For a couple hundred bucks you can get it done by an exhaust shop.  Just please, for the love of all that is decent, don't cut the mufflers off.
                      • IceddragonI
                        IceddragonI
                        Iceddragon
                        Looks like PO already did the PE mod. And I'll take your word on the mufflers and leave them alone lol, I have lots to learn about modding this thing and advice is one of the reasons I come here.
                        Case and point, your first suggestion just arrived today. I'll take it for a spin tomorrow to try it out since my car cover disappeared somehow anyway, I'll need a new one to keep birds away...
                          Hmm, that is quite possible, now that you mention it I don't think there was any resonator.
                            Nice!  The ZHP knob is awesome!
                              No lead poisoning, no care
                              • IceddragonI
                                IceddragonI
                                Iceddragon
                                Put the car on a Dyno today to see how it does stock. Numbers were 240hp and 288tq.
                                I thought it would be a little higher but the power curve is amazing.
                                  The N54 is an awesome engine
                                    Good to get baseline #s before doing upgrades.
                                    • IceddragonI
                                      IceddragonI
                                      Iceddragon
                                      I feel good about these numbers and the graph itself looks healthy. There was an mr2 on before me and his graph was a mess, like it was missing or not getting good ignition.
                                      Anyways, up we go
                                        Upgrade & slap it on a dynojet.
                                        In4gainz
                                          Pretty good!  A lot of n54 guys dyno with standard correction (std) so if you compare yours to others it may seem low since they used sae.  Figure another 10whp based on a 4% difference between the two.  Now on to mods!
