  4. '88 E30
'88 E30
savebigmoney
    I did in my car and it was fairly easy.
      As a part of the CES cut ring install, last night I refinished the block.
      Used the coarse/fine sides of the stone. Tons of brake cleaner, wd-40, lacquer thinner, rags and beer.
      Biggest thing I found was keeping the stone and block clean and well lubed. As soon as the WD started to change colors, the stone didn't seem to "cut" anymore.
      Plugged up the cylinders as best as I could with plastic and tape, oil and coolant passages will be brake cleaned and flushed to death.
      This is what I started with:(only crappy pic I took before hand) a15719fdc0de2f2d2b1151e2dff43894.jpg
      And this is what I ended with
      One step closer
        Making this engine great again.
          Hopefully
            Power steering is back in. Can't wait for that shit to leak everywhere. 45b87832d3e20f6914e9769fbf516c02.jpg
            The e36 line design is absolutely annoying
            This rack was powered when I was m50, until I dumped the s50 into the car, then I ditched the PS. It's been manual for a season-ish. Hopefully there aren't any surprises going back to power
            Here's to not trying to break my steering column in parking lots & being able to turn quickly at low speeds.
              No power steering gets you ripped though
                ^this guy knows
                  If you want to run a manual rack but dont want the struggles and aesthetics of popeye, maybe consider a Z4 manual rack.
                    manual rack ftw!
                      I've ran it PS-less for a year and at a few events. It wasn't a "ftw" type of feeling.
                      Bottom line PS is nice to have
                        That's because a PS rack without the PS is no bueno. BUT a manual rack that is made to not have PS is ftw! The e21 has a manual rack and I love it.
                          Quick steering
                          Easy steering
                          Gobs of cornering grip
                          Pick 2
                          Manual racks are fine but fighting some grippy front tires in a sudden countersteer maneuver is something id rather have power steering for.
                          Anyone who disagrees drifts on 800 treadwear snoozeradials
                            Cams in the AM
                              Was your head that clean to begin with or did the shop clean it?
                                Machine shop hot tanked it
                                  He actually licked it clean, while saying something about "practice for upcoming wibimmer meets".
                                  I think there is cause for concern.
                                    Well with uncle bens help: 1e653c33b9478bc8ec5502aef19544fa.jpg
                                    Cams are in and engine is timed, everything is torqued. Will be rechecking the ARPs after the first heat cycle
                                    Still need to flush block as well
                                    Rebuilt the vanos while he installed the cams (didn't take pics) was pretty easy. There was a decent amount of play before, not as much after. Hooray for no more marbles.
                                    Installed new Stewart pump as well
                                    Now it's just reinstalling exhaust & all other crap.
                                    Realized I sold my intake elbow, so I can't really drive it around the rest of the year NA, so I'm forcing myself to finish the SC.
                                    Looks like I'll have to figure out something for modifying the dipstick tube for a drain (or just tap the pan) as it interferes with the sc piping.
                                    Probably need to buy a new tensioner as well. Also figure out belt routing.
                                    Closer!
                                      Hey, get this done so i can get a ride when i'm up next.
                                        I'll try, been tough getting some free time as my folks are visiting this month from Nevada & spending time w/them is > e30
                                          woah woah woah
                                          you slipped that in there very non-nonchalant.
                                          thats awesome!
