  4. '88 E30
'88 E30
savebigmoney
    Auto-x'd and evo x today. It was neat. Didn't work on my car. Thought about it though
      Its the thought that counts
        Those seats look good in there. I noticed in my own car and believe I read somewhere that the steering column isn't exactly centered to the seat of E30s from the factory.
        Had to check.....http://www.r3vlimited.com/board/showthread.php?t=278956
          I'm may try and rework the bracket a touch
            I did in my car and it was fairly easy.
              As a part of the CES cut ring install, last night I refinished the block.
              Used the coarse/fine sides of the stone. Tons of brake cleaner, wd-40, lacquer thinner, rags and beer.
              Biggest thing I found was keeping the stone and block clean and well lubed. As soon as the WD started to change colors, the stone didn't seem to "cut" anymore.
              Plugged up the cylinders as best as I could with plastic and tape, oil and coolant passages will be brake cleaned and flushed to death.
              This is what I started with:(only crappy pic I took before hand) a15719fdc0de2f2d2b1151e2dff43894.jpg
              And this is what I ended with
              One step closer
                Making this engine great again.
                  Hopefully
                    Power steering is back in. Can't wait for that shit to leak everywhere. 45b87832d3e20f6914e9769fbf516c02.jpg
                    The e36 line design is absolutely annoying
                    This rack was powered when I was m50, until I dumped the s50 into the car, then I ditched the PS. It's been manual for a season-ish. Hopefully there aren't any surprises going back to power
                    Here's to not trying to break my steering column in parking lots & being able to turn quickly at low speeds.
                      No power steering gets you ripped though
                        ^this guy knows
                          If you want to run a manual rack but dont want the struggles and aesthetics of popeye, maybe consider a Z4 manual rack.
                            manual rack ftw!
                              I've ran it PS-less for a year and at a few events. It wasn't a "ftw" type of feeling.
                              Bottom line PS is nice to have
                                That's because a PS rack without the PS is no bueno. BUT a manual rack that is made to not have PS is ftw! The e21 has a manual rack and I love it.
                                  Quick steering
                                  Easy steering
                                  Gobs of cornering grip
                                  Pick 2
                                  Manual racks are fine but fighting some grippy front tires in a sudden countersteer maneuver is something id rather have power steering for.
                                  Anyone who disagrees drifts on 800 treadwear snoozeradials
                                    Cams in the AM
                                      Was your head that clean to begin with or did the shop clean it?
                                        Machine shop hot tanked it
                                          He actually licked it clean, while saying something about "practice for upcoming wibimmer meets".
                                          I think there is cause for concern.
