  4. 2003 s55 beater
2003 s55 beater
60 Posts 12 Posters 1.3k Views 1 Watching
    You should have contacted me.  My pin heads at least have the fear of me to motivate them from screwing up.
    I can attest to this. Its quite comical how customer service intensifies once Pat gets on the horn.
    Pat don't play no games
      That's what seems to happen when you go with the cheapest option. I have learned that it's not worth wasting my time (or patience with incompetent idiots) on the cheaper shop. Just go to the place that knows what the hell they are doing and pay the extra ~$20 to get service that you can actually trust.
        Once I find the right house a tire machine and balancer is the first on my list. So hopefully this is the last time I have to bring my cars anywhere except for alignments.
        Hey Pat what would you recommend for a tire machine, or not recommend
          If you want the best, get a Coats.  You can find a used one for as cheap as $500.  We've got a lot in the company that have been in service for 15+ years with minor parts being replaced.  There's also a ton of parts that are interchangeable from old to new on those so they are easy to keep running.
            Bassboy3313 said:
            What does your shop charge to mount tires if I bring the wheels/tires to you? Don't forget the WB discount. 😁
            Hahaha!  It's typically $60 for mount/dismount/balance for 4 wheels.  It usually helps to get me involved before coming into one of my shops so I can get it set up.
              Picked up some goodies soon to go in.
              90 mm bbk (big black kock) throttle body for one of them dodges
              Custom made 3k stall torque converter, have to do rear main seal so figured if the tranny is out do some mods.
              car is running good, got a check engine light for evap system (very small leak)
              cleared it and hasn't come back, I think it's due to leaving my car running when I fill up.
                I had to stop drinking my cup of water when I read this
                [emoji16]
                  Figured out my car had adjustable links, when I was checking things out for the torque converter install, in the rear for the ride height sensors (hydraulic suspension)
                  So naturally I tested them out this is only half way they were in monster truck mode.
                  The front appears to be adjustable if I were to add some washers on the bolt holding the sensor to the bottom of the upper control arm, also with a longer bolt I should hit maximum low.
                    Drive it like that yet? Looks like rub city
                      8 dollars later
                        Fancy!
                          Is that max low in front or just with a few washers?
                            It can go lower I'm testing the waters for scrapage and drivability issues, the nice thing is I can raise it either 1 inch or 2 inch from the cabin.
                                This intake is not the optional hot air intake one anymore.
                                https://youtu.be/L9RkIy0VKzs
                                  Pulling out all of the stops now I see haha
                                    Ho lee fook!
                                    Do you have to start off in 2nd to avoid having a Snoop Dogg concert form behind you?
                                    How badly do you want to murder people after pulling/installing the trans on that car without a lift? Is it tolerable?
                                    The thing friggin moves though, amazing work Dom!
                                      I can start in first, just have to ease into the throttle. That was more of a demonstration of the torque converter.
                                      Transmission was pretty easy, no diy on it so went in blind. Only thing that sucked was driveshaft had to come out, couldn't just push it to the side.
                                        There is a difference
                                          Those are probably worth 20-30hp with the sort of airflow you are dealing with. Any idea on typical gains for headers there?
