  4. 2003 s55 beater
2003 s55 beater
60 Posts 12 Posters 1.3k Views 1 Watching
    Daggerty said:
    Picked up some goodies soon to go in.
    90 mm bbk (big black kock)
    I had to stop drinking my cup of water when I read this
    [emoji16]
      Figured out my car had adjustable links, when I was checking things out for the torque converter install, in the rear for the ride height sensors (hydraulic suspension)
      So naturally I tested them out this is only half way they were in monster truck mode.
      The front appears to be adjustable if I were to add some washers on the bolt holding the sensor to the bottom of the upper control arm, also with a longer bolt I should hit maximum low.
        Drive it like that yet? Looks like rub city
          8 dollars later
            Fancy!
              Is that max low in front or just with a few washers?
                It can go lower I'm testing the waters for scrapage and drivability issues, the nice thing is I can raise it either 1 inch or 2 inch from the cabin.
                    This intake is not the optional hot air intake one anymore.
                    https://youtu.be/L9RkIy0VKzs
                      Pulling out all of the stops now I see haha
                        Ho lee fook!
                        Do you have to start off in 2nd to avoid having a Snoop Dogg concert form behind you?
                        How badly do you want to murder people after pulling/installing the trans on that car without a lift? Is it tolerable?
                        The thing friggin moves though, amazing work Dom!
                          I can start in first, just have to ease into the throttle. That was more of a demonstration of the torque converter.
                          Transmission was pretty easy, no diy on it so went in blind. Only thing that sucked was driveshaft had to come out, couldn't just push it to the side.
                            There is a difference
                              Those are probably worth 20-30hp with the sort of airflow you are dealing with. Any idea on typical gains for headers there?
                                50whp stock and it just goes up with supporting mods.
                                  I'll do the headers first. To clarify these headers are for an e55, which is slightly smaller then my s55. The price tag for the s55 was 3.5x the price so I figured I'd make them work. IMG1141.JPG
                                  this was the first issue on the passenger side. Subframe heat shield I was able to cut that out, the smooth one, and push down the ribbed one onto the subframe. It's not by any bushings or rubber so it really doesn't need any protection at all. Then removed the bolt and shaved it so it was flush with the nut and gave the pipe the one two with a hammer for decent clearance.
                                  The end of the header was resting up on the bottom of the car. Used a floor jack on the floor pan to make some extra room. That's about as far as I got on that. I'll have pictures within a year.
                                  Now onto the BBK.
                                  Got it mocked up where I want it, this BBK is a tight fit. Notice in the bottom left it is almost touching the fpr, on the right it is touching (what they call a surge tank in Mercedes land) but I would call intake manifold or intake runner. I have to shave off the protruding engraved bbk logo, very little, too fit.
                                  I'm basically going to fill the shit out of the little snout where the throttle body connects and have a machine shop bore it out so I can drill and tap mounting holes. Obviously I will have them machine the matting surfaces flat. Open to recommendations on machine shops. Comparison of old vs new.
                                    Got the snout pretty much complete on my end, I'm going to bring it to the machine shop on Tuesday.
                                    also had to make some room for the headers on the driver side by chopping a chunk out of the subframe. It was just an extra tab for mounting hydraulic lines so no structural issues. The driver side collector outlet hits the floor and I can't make any more room with a hammer so I'm going to be cutting it and welding it on at a downward angle.IMG1319.JPG
                                      My dude
                                        Ecu, climate control module/unit, and driver side seat belt retractor module went bad. Haven't ran the car in a month and battery was to week so I put a jump pack on. I think that might be related but no idea.
                                        So the good news, swapped the climate control unit, there were some dead pixels in the old one and the parts car one was perfect so that's a win. Seat belt retractor in do time, srs warning.
                                        Bad news, ecu has to be replaced with a matching set as follows. Ezs (ignition switch module) with key, shifter module, and ecu. "Well you have a parts car so that should be all good" no, ezs is fried, not just literally.
                                        My options are
                                        find a matching set (very hard for s55 plus needs to be keyless go)
                                        Buy a new one from the dealer $1000 and program it.
                                        final option which I'm going to do. Send to the tuner who can virginize the parts Ecu and use the whatever ma whos on the old one to make it work.
                                        I figured I would share this, as for the base edition person this would be detrimental. $$$
                                          Germany stuff is different from Japan stuff, but on my Infiniti I can register a new VIN in the ECU with a laptop and the Nissan Consult-II diagnostics program.
                                          Perhaps there is hope for a DIY in the MB world too?
