  4. 2003 s55 beater
2003 s55 beater
60 Posts 12 Posters 0 Views 1 Watching
    even faster? geez.
      Went ahead and put the summer tires on yesterday.
      Went to a couple different places to get some prices for taking winter tires off and summers put on.
      discount tire $150
      tires plus $90
      firestone $55
      So I went to firestone where zippy the pin head put my tires on, quite impressive watching this considering his pants were falling off.
      I told the manager make sure they put the tires on right because the rims are staggered, the 295s go on the 9 inch rim.
      "But these are 18 inch rims?"
      "don't worry we're professionals I'll make sure we get it right."
      well they get my wheels on and I notice one of the rear tires has some pretty excessive bulge so I say, you put the wrong tire on this rim.
      "no we put the wider tires in the rear"
      then I say, yeah but the rim width is different for this wheel
      "manufacturers make all the rims the same size"
      words exchanged
      "well they are already on there"
      Long story short, I had them take the wheels off and show them how you read the rim size.
      They fixed the issue at end of the day
      rant over....
      Front 265 40 18
      rear 295 35 18
      cuntinentals dws
      pictures don't do it justice
        I was wondering why snow was suddenly in the forecast again!
        Hahaha
          You should have contacted me.  My pin heads at least have the fear of me to motivate them from screwing up.
            What does your shop charge to mount tires if I bring the wheels/tires to you? Don't forget the WB discount. 😁
              Holy dumb sauce
                I can attest to this. Its quite comical how customer service intensifies once Pat gets on the horn.
                  Pat don't play no games
                    That's what seems to happen when you go with the cheapest option. I have learned that it's not worth wasting my time (or patience with incompetent idiots) on the cheaper shop. Just go to the place that knows what the hell they are doing and pay the extra ~$20 to get service that you can actually trust.
                      Once I find the right house a tire machine and balancer is the first on my list. So hopefully this is the last time I have to bring my cars anywhere except for alignments.
                      Hey Pat what would you recommend for a tire machine, or not recommend
                        If you want the best, get a Coats.  You can find a used one for as cheap as $500.  We've got a lot in the company that have been in service for 15+ years with minor parts being replaced.  There's also a ton of parts that are interchangeable from old to new on those so they are easy to keep running.
                          Hahaha!  It's typically $60 for mount/dismount/balance for 4 wheels.  It usually helps to get me involved before coming into one of my shops so I can get it set up.
                            Picked up some goodies soon to go in.
                            90 mm bbk (big black kock) throttle body for one of them dodges
                            Custom made 3k stall torque converter, have to do rear main seal so figured if the tranny is out do some mods.
                            car is running good, got a check engine light for evap system (very small leak)
                            cleared it and hasn't come back, I think it's due to leaving my car running when I fill up.
                              I had to stop drinking my cup of water when I read this
                              [emoji16]
                                Figured out my car had adjustable links, when I was checking things out for the torque converter install, in the rear for the ride height sensors (hydraulic suspension)
                                So naturally I tested them out this is only half way they were in monster truck mode.
                                The front appears to be adjustable if I were to add some washers on the bolt holding the sensor to the bottom of the upper control arm, also with a longer bolt I should hit maximum low.
                                  Drive it like that yet? Looks like rub city
                                    8 dollars later
                                      Fancy!
                                        Is that max low in front or just with a few washers?
                                          It can go lower I'm testing the waters for scrapage and drivability issues, the nice thing is I can raise it either 1 inch or 2 inch from the cabin.
