  3. BMW Discussion
  4. E46 help. Please
E46 help. Please
25 Posts 7 Posters 393 Views 1 Watching
  • ThatRatRodProjectT
    ThatRatRodProjectT
    ThatRatRodProject
    You can't properly get a good look at the pattern for a cam sensor without a scope.  The circuit for a cam sensor is pretty simple so unless you nicked a wire while doing the evap stuff then it was nothing you caused.  The signal goes straight from the cam sensor to the ECU so the check engine light is only reporting data that the sensor is giving.  I would assume it's either vanos related or the cam sensor actually is faulty.  I'd lean towards a vanos solenoid issue.
    Is it common that the vanos solenoid fails or that it just gets dirty.
      Fairly common.
        I only ask if an oil change was recently performed because i recently heard of someone discarding an important piece of the oil filter assembly while doing an oil change. Its a frequent enough variable so i thought id ask
          ThatRatRodProjectT
          ThatRatRodProject
          Fairly common.
          Common fails or gets dirty.
            More get dirty but they also fail.  Neither would surprise me.
            • dastuzD
              dastuzD
              dastuz
              I know I'm late to the party and this recommendation is also potentially late...  I know on my S-motor I replace the micro filter on my Vanos unit roughly once a year.  It's super cheap, super easy to do, and I know a few people who have had a lot of luck with that preventing Vanos issues.
              $0.02
                ThatRatRodProjectT
                ThatRatRodProject
                $0.02
                Thanks for the info. I will also clean that filter.
                  ThatRatRodProjectT
                  ThatRatRodProject
                  Well I went threw cleaned everything rest the codes. Drive about a 175 miles and SES light comes back. Plug in the scanner and it's the secondary air bank one and secondary air bank two. I have replaced the smog pump. Checked the evap valve with a vacuum pump. It was between 15" and 18" of vacuum so that's fine. So I then checked the vacuum control switch. No vacuum. Replaced the line and the switch. Still no vacuum. So next step was I check to see if I was getting power at plug for the vacuum control valve. There was power at the plug. I then tested the valve it self ran power to the control switch and the valve opened. I blew in one end air came out the other. Then I put it all back together and check it again this morning. Still no vacuum. Yes I check the fuses. Any help would be great. Good thing no more cam sensors check engine light.
                    Standard protocol is to send donuts to those in the thread that contributed to a diagnosis
                      ThatRatRodProjectT
                      ThatRatRodProject
                      Alright sounds fair
                        Or get lost and eat them yourself
                          Are you checking for power by grounding it through the circuit?
                            No, you dont get any donuts
                              ThatRatRodProjectT
                              ThatRatRodProject
                              No exactly sure what you mean. Grounded to the chassis or to the plug.
                                Are you grounding it through the plug?
                                  ThatRatRodProjectT
                                  ThatRatRodProject
                                  Yes
                                    What power reading are you getting through the plug.
                                    when testing vacuum are you using your vacuum pump to build the vacuum in the system, or just to read it?
                                      ThatRatRodProjectT
                                      ThatRatRodProject
                                      I just took everything apart and put it back together. And the vacuum line was pinched on the valve cover everything is working correctly now.
                                        K.I.S.S Theory, Keep It Simple Stupid!
