  3. BMW Discussion
  4. E46 help. Please
E46 help. Please
25 Posts 7 Posters 393 Views 1 Watching
  • ThatRatRodProjectT
    ThatRatRodProjectT
    ThatRatRodProject
    So I had check engine light for the secondary air pump. Witch was one of three things. The pump the evap valve and the control switch. Turns outs the pump and vacuum control switch. So I got everything in that system to checkout and work. But immediately after fixing this problem. I got another code a POO11. I guess I'm wondering is this is because of something that I did. I look up symptoms of a faulty cam sensor. And I do not have any symptoms that point to a faulty cam sensor. I took pictures of Live stream data at idle about two grand and at four grand.
    Any information or pointers would be great.
    Can personally message me at 262 483 0545.
    Or respond on the forum.
    e40d838dcf8ab71c70aa9951f3ea0e94.jpg575da70fec40bde8bbd2fd4c6c5f65a2.jpgdc84e527a1240f8930d730792b080f87.jpg734681abe6cb97e74335aa76b44a2f30.jpg58e983eca450aa034ca58fd29870003a.jpg701eda7d1e9e6c45c883250bdca48144.jpgf1f3d9b780f43bbe7fdcab3f1a341388.jpg
      sorry can't help you with the CEL issue, but no need for you to post this 3 times all across the forums. its pretty small here, people will see it in one place.
        ThatRatRodProjectT
        ThatRatRodProject
        I've had a issues with the forum not working properly. And I'm pressed for time on fixing the problem just wanted inside as soon as possible.
          Did you recently do an oil change?
          You may want to look into cleaning the vanos solenoid(s). I dont want to send you on a wild goose chase with unnecessary tasks, but its fairly simple and worth looking into
            ThatRatRodProjectT
            ThatRatRodProject
            I will definitely be doing this I'm not due for a oil change yet but I'm going to do one today to try to remove any possible reasons why it would be acting up. Thanks for the response.
              You can't properly get a good look at the pattern for a cam sensor without a scope.  The circuit for a cam sensor is pretty simple so unless you nicked a wire while doing the evap stuff then it was nothing you caused.  The signal goes straight from the cam sensor to the ECU so the check engine light is only reporting data that the sensor is giving.  I would assume it's either vanos related or the cam sensor actually is faulty.  I'd lean towards a vanos solenoid issue.
                ThatRatRodProjectT
                ThatRatRodProject
                Is it common that the vanos solenoid fails or that it just gets dirty.
                  Fairly common.
                    I only ask if an oil change was recently performed because i recently heard of someone discarding an important piece of the oil filter assembly while doing an oil change. Its a frequent enough variable so i thought id ask
                      ThatRatRodProjectT
                      ThatRatRodProject
                      Fairly common.
                      Common fails or gets dirty.
                        More get dirty but they also fail.  Neither would surprise me.
                        • dastuzD
                          dastuzD
                          dastuz
                          I know I'm late to the party and this recommendation is also potentially late...  I know on my S-motor I replace the micro filter on my Vanos unit roughly once a year.  It's super cheap, super easy to do, and I know a few people who have had a lot of luck with that preventing Vanos issues.
                          $0.02
                            ThatRatRodProjectT
                            ThatRatRodProject
                            $0.02
                            Thanks for the info. I will also clean that filter.
                              ThatRatRodProjectT
                              ThatRatRodProject
                              Well I went threw cleaned everything rest the codes. Drive about a 175 miles and SES light comes back. Plug in the scanner and it's the secondary air bank one and secondary air bank two. I have replaced the smog pump. Checked the evap valve with a vacuum pump. It was between 15" and 18" of vacuum so that's fine. So I then checked the vacuum control switch. No vacuum. Replaced the line and the switch. Still no vacuum. So next step was I check to see if I was getting power at plug for the vacuum control valve. There was power at the plug. I then tested the valve it self ran power to the control switch and the valve opened. I blew in one end air came out the other. Then I put it all back together and check it again this morning. Still no vacuum. Yes I check the fuses. Any help would be great. Good thing no more cam sensors check engine light.
                                Standard protocol is to send donuts to those in the thread that contributed to a diagnosis
                                  ThatRatRodProjectT
                                  ThatRatRodProject
                                  Alright sounds fair
                                    Or get lost and eat them yourself
                                      Are you checking for power by grounding it through the circuit?
                                        No, you dont get any donuts
                                          ThatRatRodProjectT
                                          ThatRatRodProject
                                          No exactly sure what you mean. Grounded to the chassis or to the plug.
