    Today was pretty successful. First I installed the new ignition switch permanently from where I had that mishap on the way to the holy hill cruise. So that's done.
    I then installed the dead pedal I got from father hundley. Feels good.
    After that I started making fiberglass molds of the rear hood rollers mounts to put in the fiberglass hood. All went well, but I think I didn't use enough hardner in the resin. Shit!! We will see if guess.
    Mounted a fire extinguisher to the trans tunnel since you never know when you'll need it, lol.
    Lastly, I installed a Painless wiring remote master battery cutoff switch. It is comprised of a solenoid that gets mounted near battery. Solenoid gets wired in line of the positive battery cable. Then a small gauge wire runs up to a switch on the dash (which I used a master cutoff switch for its removeable key) which switches the ground. Turning the solenoid on or off.
    What I have left to do is finish the rollers on the hood, find the boost leak and ground the alternator to see if that solves my lower voltage reading.
      Life gets a little bit better when you have a rubber pad on your clutch pedal.
        Yeah Yeah yeah
          If lightning strikes the ground, travels along a puddle of water and arcs to your transmission and you are driving bare-foot,
          Welp, you could dead.
          That pedal cover may just save your life
            Snap, this is a racecar!
            Dave, apply some griptape to all of your pedals for max grip!
              In a pinch: Gorilla glue some 80 grit sandpaper to it
                I ordered 2 bmw pedal covers. Happy now?
                  Two? FYI: Dual clutch wasn't an option until the e90
                    Hood is just about done with the rear roller modifications. Not perfect, but when are fiberglass parts a perfect fit anyways, right?
                      In this photo:
                      Zorro has left his mark.
                      SpongeBob has also left his mark.
                      The Toothed-wheel fairy paid a visit.
                        For the love of Gotti, please put the flares on too=(
                          Patience my friend. Body work is a winter project
                          • i_love_carsI
                            i_love_carsI
                            i_love_cars
                            BRRRAAAAAAAAAAPP
                            2007 Z4MR
                            2003 E39 M5
                            2002 E46 M3
                            2021 X5 40i
                                  So I have decided on doing a high gloss vinyl wrap on the car instead of paying thousands for a paint job. I've been talking with a local vehicle wrap company (Diamond Graphics, LLC in Cedarburg) and one of the guys even dropped off a few color books at my house for me to look through. I have been jumping around with colors a lot since I am kind of indecisive when it comes to things like this. First was white, then I thought about an olive green or super dark green, but now I am more dead set on orange. Seeing this obviously helped...
                                  Looking through the color sample books, here are the oranges that I found caught my eye the most. I know colors look different depending on what type of screen you are looking at them on and so forth, but what do you guys think. Looking for your opinions. I am leaning towards Arlon 4600LX-383 Gloss Bright Orange.
                                    Have to see them on the car to make up your mind dude
                                      That's the thing, holding up a 3" square sample piece still doesn't give you the right visual of what the entire car will look like anyways.
                                        You can order enough to do a fender for probably like $60
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          Good call on orange. A shouty body kit calls for a shouty color.
