813 Posts 31 Posters 0 Views 1 Watching
    Went out last night for a longer cruise/tune session with Brian as my tuner. We dialed in a lot of different areas of the fuel map and changed some settings around too. Car is driving way smoother now. Love it!! The only issues as of right now are what looks to be a small boost leak, so I will be snugging up all the charge piping clamps and turbo compressor housing bolts. And an idle surge that seemed to have started after a lot of driving. We are thinking it has something to do with temp sensor heatsoak and/or looking at the temp compensation curve in megasquirt.
    Goal for this weekend is to finish the rear roller mounts on the fiberglass hood and get that installed. Still looking for a good material to use on the underside of the hood for sound deadening and some heat protection.
      Today was pretty successful. First I installed the new ignition switch permanently from where I had that mishap on the way to the holy hill cruise. So that's done.
      I then installed the dead pedal I got from father hundley. Feels good.
      After that I started making fiberglass molds of the rear hood rollers mounts to put in the fiberglass hood. All went well, but I think I didn't use enough hardner in the resin. Shit!! We will see if guess.
      Mounted a fire extinguisher to the trans tunnel since you never know when you'll need it, lol.
      Lastly, I installed a Painless wiring remote master battery cutoff switch. It is comprised of a solenoid that gets mounted near battery. Solenoid gets wired in line of the positive battery cable. Then a small gauge wire runs up to a switch on the dash (which I used a master cutoff switch for its removeable key) which switches the ground. Turning the solenoid on or off.
      What I have left to do is finish the rollers on the hood, find the boost leak and ground the alternator to see if that solves my lower voltage reading.
        Life gets a little bit better when you have a rubber pad on your clutch pedal.
          Yeah Yeah yeah
            If lightning strikes the ground, travels along a puddle of water and arcs to your transmission and you are driving bare-foot,
            Welp, you could dead.
            That pedal cover may just save your life
              Snap, this is a racecar!
              Dave, apply some griptape to all of your pedals for max grip!
                In a pinch: Gorilla glue some 80 grit sandpaper to it
                  I ordered 2 bmw pedal covers. Happy now?
                    Two? FYI: Dual clutch wasn't an option until the e90
                      Hood is just about done with the rear roller modifications. Not perfect, but when are fiberglass parts a perfect fit anyways, right?
                        In this photo:
                        Zorro has left his mark.
                        SpongeBob has also left his mark.
                        The Toothed-wheel fairy paid a visit.
                          For the love of Gotti, please put the flares on too=(
                            Patience my friend. Body work is a winter project
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              BRRRAAAAAAAAAAPP
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                                    So I have decided on doing a high gloss vinyl wrap on the car instead of paying thousands for a paint job. I've been talking with a local vehicle wrap company (Diamond Graphics, LLC in Cedarburg) and one of the guys even dropped off a few color books at my house for me to look through. I have been jumping around with colors a lot since I am kind of indecisive when it comes to things like this. First was white, then I thought about an olive green or super dark green, but now I am more dead set on orange. Seeing this obviously helped...
                                    Looking through the color sample books, here are the oranges that I found caught my eye the most. I know colors look different depending on what type of screen you are looking at them on and so forth, but what do you guys think. Looking for your opinions. I am leaning towards Arlon 4600LX-383 Gloss Bright Orange.
                                      Have to see them on the car to make up your mind dude
                                        That's the thing, holding up a 3" square sample piece still doesn't give you the right visual of what the entire car will look like anyways.
                                          You can order enough to do a fender for probably like $60
