  4. 96 328is Passenger Rear Brake Issue
36 Posts 7 Posters 585 Views 1 Watching
    Maybe it's the 17x11 wheels 😃
    Any debris in the shield?
    This is on stock wheels
      Hm
      100% positive the hub is in perfectly
        shooting in the dark here, as it seems like you've eliminate almost everything to do with the brakes/rotor/ebrake/wheels/etc.
        the dust plates on the rear diff inputs/outputs can make that noise if they start rubbing on the case or something becomes lodged in them. i guess braking could cause just enough driveline movement to make the sound increase?
        I'll take a peek at that. I just find it odd that this happened the day I did RTABs but it has had nothing to do with anything I touched when I replaced them
          well if you replaced rtabs, then the whole trailing arm could be slightly moved compared to before, what might this effect? axles/stubs/wheel bearings would be on that list.
            e36.PNG.25c1bbf8562a2402c13d04c8a5c9ba1c
            56f1a850707cde36-1.PNG.bd07d84107c39c47
              It's definitely a brake related issue.
                The only thing it could be from that list is that the vent bore of the master is clogged.
                  Guide pins all lubed and crap?
                    Brand new caliper lol. Lubed to the T. Let's put it this way. From the hardlines to the caliper, there are no issues.
                    Just noticed if I lock my brakes up to stop, my caliper sticks pretty good until I start to move. Something isn't allowing the pressure to relieve normally.
                      coincidence it started when you did your rtabs?
                        Anything in the union? Maybe some crap in there?
                          Going to swap out the master tomorrow and do a full fluid flush to see what happens.
                            Moving the trailing arm to do the rtabs could have dislodged a chunk of something in the brake line. Is the little hard line that is attached to the trailing arm new/clean?
                              It isn't new but it is nice and clean
                                Noticed something I hadn't before. I was sitting in my car yesterday after driving it and could hear the pressure relieving in spurts from the caliper and then a simultaneous pressure relief noise coming from the master.
                                  Id replace the engine. Just to be sure.
                                  If it was the master, why would it happen on the caliper that's farthest away?
                                    It is something not allowing the pressure to be relieved but the only things that could do that are the master and possibly the ABS. I have never seen something like this and it is frustrating lol
                                      Maybe try and do a complete fluid flush at all 4 corners? Might help clear out any junk that is causing a blockage?
                                        I'm just going to swap the master at the same time since it is only removing two lines and two nuts once emptied anyways. I have two liters of ATE Type 200 for doing this already as well. The extra liter is incase I have issues=)
                                          Just turn your radio up louder so you can't hear any noises.
