  4. 96 328is Passenger Rear Brake Issue
36 Posts 7 Posters 629 Views 1 Watching
    Maybe an early wheel bearing failure? Its possible to not have noise or noticeable play when rotating it on a stand, but under the weight of the car it could potentially make a faint noise and hitting the brakes could affect the sound.
    Ooor, do you have access to one of those infrared thermometer things? You can use them to take the temperatures of each rotor after a long drive. One being hotter than the other would indicate dragging pads.
    Just throwin' some ideas out there
      I know you replaced the wheel bearings right? That's the only thing that's changed correct? If it was at a goofy angle, could the hub be cocked causing one side of the rotor to make contact with a pad?
        Wheel bearing is tight and was replaced in November. The noise sounds like metal being taken to a grinding stone so I am not sure what else would cause that noise when you touch the brakes lol
          Maybe it's the 17x11 wheels 😃
          Any debris in the shield?
            shooting in the dark here, as it seems like you've eliminate almost everything to do with the brakes/rotor/ebrake/wheels/etc.
            the dust plates on the rear diff inputs/outputs can make that noise if they start rubbing on the case or something becomes lodged in them. i guess braking could cause just enough driveline movement to make the sound increase?
              This is on stock wheels
                Hm
                100% positive the hub is in perfectly
                  I'll take a peek at that. I just find it odd that this happened the day I did RTABs but it has had nothing to do with anything I touched when I replaced them
                    well if you replaced rtabs, then the whole trailing arm could be slightly moved compared to before, what might this effect? axles/stubs/wheel bearings would be on that list.
                      e36.PNG.25c1bbf8562a2402c13d04c8a5c9ba1c
                      56f1a850707cde36-1.PNG.bd07d84107c39c47
                        It's definitely a brake related issue.
                          The only thing it could be from that list is that the vent bore of the master is clogged.
                            Guide pins all lubed and crap?
                              Brand new caliper lol. Lubed to the T. Let's put it this way. From the hardlines to the caliper, there are no issues.
                              Just noticed if I lock my brakes up to stop, my caliper sticks pretty good until I start to move. Something isn't allowing the pressure to relieve normally.
                                coincidence it started when you did your rtabs?
                                  Anything in the union? Maybe some crap in there?
                                    Going to swap out the master tomorrow and do a full fluid flush to see what happens.
                                      Moving the trailing arm to do the rtabs could have dislodged a chunk of something in the brake line. Is the little hard line that is attached to the trailing arm new/clean?
                                        It isn't new but it is nice and clean
                                          Noticed something I hadn't before. I was sitting in my car yesterday after driving it and could hear the pressure relieving in spurts from the caliper and then a simultaneous pressure relief noise coming from the master.
