  4. 96 328is Passenger Rear Brake Issue
36 Posts 7 Posters 585 Views 1 Watching
    coincidence it started when you did your rtabs?
      Anything in the union? Maybe some crap in there?
        Going to swap out the master tomorrow and do a full fluid flush to see what happens.
          Moving the trailing arm to do the rtabs could have dislodged a chunk of something in the brake line. Is the little hard line that is attached to the trailing arm new/clean?
            It isn't new but it is nice and clean
              Noticed something I hadn't before. I was sitting in my car yesterday after driving it and could hear the pressure relieving in spurts from the caliper and then a simultaneous pressure relief noise coming from the master.
                Id replace the engine. Just to be sure.
                If it was the master, why would it happen on the caliper that's farthest away?
                  It is something not allowing the pressure to be relieved but the only things that could do that are the master and possibly the ABS. I have never seen something like this and it is frustrating lol
                    Maybe try and do a complete fluid flush at all 4 corners? Might help clear out any junk that is causing a blockage?
                      I'm just going to swap the master at the same time since it is only removing two lines and two nuts once emptied anyways. I have two liters of ATE Type 200 for doing this already as well. The extra liter is incase I have issues=)
                        Just turn your radio up louder so you can't hear any noises.
                          Did a full fluid flush with no change at all=/ Was about to swap out my master with the one from the compact but that has a 12mm front port and an 11mm rear port instead of two 11mm ports. I should be able to use an adapter to install it to do some troubleshooting as I see nothing else being the culprit=/
