  4. e39 blower motor issue
21 Posts 5 Posters 379 Views 1 Watching
  • Delias95D
    Delias95D
    Delias95
    Nothing at all. Just randomly stopped im leaning towards the fsu???
      If it were the fsu then you would have blower action in the highest setting.  You probably lost your blower motor.  Was it making any noise before it failed?  ticking, squealing, etc?  I would check EVERY fuse with a test light before I replaced the blower motor.  There could be another circuit controlling the blower action that you have overlooked.
      • Delias95D
        Delias95D
        Delias95
        It woukd make a little noise every now and then not anything concerning
          Any noise coming from your blower motor is concerning lol.  When they start to make noise that means they're starting to go or you have debris in there.  Could be days, months, years, who know's.  The point is, they shouldn't make noise.
          Check all fuses with a test light as this will eliminate all options.  If you have a voltmeter you can check and see if power is getting to the BM at the plug.
          • Delias95D
            Delias95D
            Delias95
            Forsure thanks.
              I had to replace an e32 blower motor, it had eaten through its bushings until the rotor was rubbing the stator. I found a used one otherwise someone mentioned in a forum about a using a certain Mercedes blower that was almost the same dimensions but much cheaper for some reason. I replaced it from under the hood by removing the plastic cover. It was not easy but seemed better than removing the whole hvac box inside the car.
              • Delias95D
                Delias95D
                Delias95
                E32 and e39 the same? Honestly there was little to no noise to indicate the blower was bad. I said abive there might have been some noise but the more i thinkof it any noise i heard was onsidered normal to me as iv owned roughly 110 cars.  But who knows going to have to get down and look
                • Delias95D
                  Delias95D
                  Delias95
                  Iv been reading forums sll day and the fsu can fail and cause no blower action at all settings
                    That's not been my experience before but the fsu is the simplest part to replace if you want to start throwing parts at it.
                      Not to thread jack, but owned close to 110 cars? That sounds like an obscure amount...
                      • Delias95D
                        Delias95D
                        Delias95
                        Yeah too many thats a rough number. But in that ball park lol
                        • Delias95D
                          Delias95D
                          Delias95
                          Well i have been under looking for fuses 75 and 76 i can onky find one fuse under the glove box area i removed what i could and all i see is one larger 50a fuse that does not look to be blown i belive i am hearing a little noise in the area while my head was down there i was hearing an almost thunping noise and the car has been off almost all day. When i turn the fan on it does not work but i hear an ever so slight noise. Any suggestions on finding that other fuse or the noise i am hearing lol
                            Test every fuse with a test light or multimeter.  You can have a bad fuse and not see it.
                            • CMartC
                              CMartC
                              CMart
                              It's pretty easy to bench test the blower as well. If it's good you know you have a fuse/control issue.
                              Excursion 7.3
                              E30 LS1
                              • Delias95D
                                Delias95D
                                Delias95
                                • Delias95D
                                  Delias95D
                                  Delias95
                                  Update: i swapped fsu with new one from autozone and noluck i can only find one fuse under the dash any info on where the other one is? Everywhere i look shows them next to each other. Helppp
                                  • Delias95D
                                    Delias95D
                                    Delias95
                                    Only fuse i see
                                    • Delias95D
                                      Delias95D
                                      Delias95
                                      Update: well i should have listened when they said doubke check all fuses. Turnes out the fuse i replaced (28) was bad and i didnt notice it?  When i originaly replaced fuse 28(was blown) it didnt work at all still. Replaced with a 10a(calls for a 30a but thats all i had on hand) started up and worked great. Not to my surprise that fuse blew right away i will be buying a new 30a and enjoying my heat another day
