  4. e39 blower motor issue
21 Posts 5 Posters 379 Views 1 Watching
  • Delias95D
    Delias95D
    Delias95
    If it were the fsu then you would have blower action in the highest setting.  You probably lost your blower motor.  Was it making any noise before it failed?  ticking, squealing, etc?  I would check EVERY fuse with a test light before I replaced the blower motor.  There could be another circuit controlling the blower action that you have overlooked.
    Iv been reading forums sll day and the fsu can fail and cause no blower action at all settings
      That's not been my experience before but the fsu is the simplest part to replace if you want to start throwing parts at it.
        Not to thread jack, but owned close to 110 cars? That sounds like an obscure amount...
        • Delias95D
          Delias95D
          Delias95
          Yeah too many thats a rough number. But in that ball park lol
          • Delias95D
            Delias95D
            Delias95
            Well i have been under looking for fuses 75 and 76 i can onky find one fuse under the glove box area i removed what i could and all i see is one larger 50a fuse that does not look to be blown i belive i am hearing a little noise in the area while my head was down there i was hearing an almost thunping noise and the car has been off almost all day. When i turn the fan on it does not work but i hear an ever so slight noise. Any suggestions on finding that other fuse or the noise i am hearing lol
              Test every fuse with a test light or multimeter.  You can have a bad fuse and not see it.
              • CMartC
                CMartC
                CMart
                It's pretty easy to bench test the blower as well. If it's good you know you have a fuse/control issue.
                Excursion 7.3
                E30 LS1
                • Delias95D
                  Delias95D
                  Delias95
                  • Delias95D
                    Delias95D
                    Delias95
                    Update: i swapped fsu with new one from autozone and noluck i can only find one fuse under the dash any info on where the other one is? Everywhere i look shows them next to each other. Helppp
                    • Delias95D
                      Delias95D
                      Delias95
                      Only fuse i see
                      • Delias95D
                        Delias95D
                        Delias95
                        Update: well i should have listened when they said doubke check all fuses. Turnes out the fuse i replaced (28) was bad and i didnt notice it?  When i originaly replaced fuse 28(was blown) it didnt work at all still. Replaced with a 10a(calls for a 30a but thats all i had on hand) started up and worked great. Not to my surprise that fuse blew right away i will be buying a new 30a and enjoying my heat another day
