  4. e39 blower motor issue
21 Posts 5 Posters 0 Views 1 Watching
  • Delias95D
    Delias95D
    Delias95
    Driving like normal and randomly the blower quit. Checked glove box fuses fuse 28 was blown replaced it and nothing changed. All other fuses looked okay. Any suggestion on whay to check next. I had my battery disconnected today for like 10 minutes if that may have anything to do with
    • CMartC
      CMartC
      CMart
      I've got an extra blower. You can use it to see if that is your problem.
      Excursion 7.3
      E30 LS1
        Do you get anything from the blower on the highest setting?
        • Delias95D
          Delias95D
          Delias95
          Nothing at all. Just randomly stopped im leaning towards the fsu???
            If it were the fsu then you would have blower action in the highest setting.  You probably lost your blower motor.  Was it making any noise before it failed?  ticking, squealing, etc?  I would check EVERY fuse with a test light before I replaced the blower motor.  There could be another circuit controlling the blower action that you have overlooked.
            • Delias95D
              Delias95D
              Delias95
              It woukd make a little noise every now and then not anything concerning
                Any noise coming from your blower motor is concerning lol.  When they start to make noise that means they're starting to go or you have debris in there.  Could be days, months, years, who know's.  The point is, they shouldn't make noise.
                Check all fuses with a test light as this will eliminate all options.  If you have a voltmeter you can check and see if power is getting to the BM at the plug.
                • Delias95D
                  Delias95D
                  Delias95
                  Forsure thanks.
                    I had to replace an e32 blower motor, it had eaten through its bushings until the rotor was rubbing the stator. I found a used one otherwise someone mentioned in a forum about a using a certain Mercedes blower that was almost the same dimensions but much cheaper for some reason. I replaced it from under the hood by removing the plastic cover. It was not easy but seemed better than removing the whole hvac box inside the car.
                    • Delias95D
                      Delias95D
                      Delias95
                      E32 and e39 the same? Honestly there was little to no noise to indicate the blower was bad. I said abive there might have been some noise but the more i thinkof it any noise i heard was onsidered normal to me as iv owned roughly 110 cars.  But who knows going to have to get down and look
                      • Delias95D
                        Delias95D
                        Delias95
                        Iv been reading forums sll day and the fsu can fail and cause no blower action at all settings
                          That's not been my experience before but the fsu is the simplest part to replace if you want to start throwing parts at it.
                            Not to thread jack, but owned close to 110 cars? That sounds like an obscure amount...
                            • Delias95D
                              Delias95D
                              Delias95
                              Yeah too many thats a rough number. But in that ball park lol
                              • Delias95D
                                Delias95D
                                Delias95
                                Well i have been under looking for fuses 75 and 76 i can onky find one fuse under the glove box area i removed what i could and all i see is one larger 50a fuse that does not look to be blown i belive i am hearing a little noise in the area while my head was down there i was hearing an almost thunping noise and the car has been off almost all day. When i turn the fan on it does not work but i hear an ever so slight noise. Any suggestions on finding that other fuse or the noise i am hearing lol
                                  Test every fuse with a test light or multimeter.  You can have a bad fuse and not see it.
                                  • CMartC
                                    CMartC
                                    CMart
                                    It's pretty easy to bench test the blower as well. If it's good you know you have a fuse/control issue.
                                    Excursion 7.3
                                    E30 LS1
                                    • Delias95D
                                      Delias95D
                                      Delias95
                                      • Delias95D
                                        Delias95D
                                        Delias95
                                        Update: i swapped fsu with new one from autozone and noluck i can only find one fuse under the dash any info on where the other one is? Everywhere i look shows them next to each other. Helppp
                                        • Delias95D
                                          Delias95D
                                          Delias95
                                          Only fuse i see
