  4. 135i build thread. I'm done hobcobbling posts together
109 Posts 16 Posters 2.2k Views 1 Watching
  • i_love_carsI
    i_love_carsI
    i_love_cars
    This makes me happy. While I'm sure your 135 was a blast on the track, I'm sure it would be more painful to write off (and sad) than an NA that you could replace in a heartbeat.
    that is absolutely the logic behind it.  Well, that and it makes tracking WAY more affordable for me. Not having to drop $300 per event for insurance frees up enough money that I can do more events. I eventually want to instruct so I need as much seat time as I can. Consumables are cheaper and so much less wear and tear with how light the car is.
    also not having to compromise the ride quality of the BMW and being able to just now focus on straight-line power for the 135i where it shines, and for the money I could sink into it, it still wouldn't be as fast around the track as the Miata.
    2007 Z4MR
    2003 E39 M5
    2002 E46 M3
    2021 X5 40i
      You'll enjoy this. I used to track a 93 Miata. Fun cars, huge aftermarket, cheap to run, and the challenge of 'spec piñata' if you decide to step up the ladder to club racing.
        As I said on 1Addicts, congrats on your purchase. I miss my '96 turbo Miata. That was the car that really switched my mindset from form to function. It was also the car that really got me into cars. I'd love to buy another one someday.
          As I said on blackpeoplemeet.com, I really dig that color.
            As I said on farmersonly.com, your wood shavings look soft, wanna bed me down?
              As Earl said on stanceworks.com, "sick, bro."
                Clashing the subie, Mazdarati, and BMW community all in one house. 👍
                • i_love_carsI
                  i_love_carsI
                  i_love_cars
                  don't forget Honda! I've got a Honda Pilot too
                  2007 Z4MR
                  2003 E39 M5
                  2002 E46 M3
                  2021 X5 40i
                  • T
                    T
                    tsweers89
                    As much as I'm thankful you didn't have kumrow do the work. Doing it in your garage without a lift will be so much of a pain in the ass. Dropping the subframe is really needed to get in there. But good luck to you. We just installed a pair of Hexon r550s in a e90 335i and long with motiv port injection. The power is insane even at only 15psi.
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      Well, fingers crossed here because I have a friend locally that has a lift and the hydraulic tools needed to drop a subframe from up that high once disconnected. I've tapped on his garage in the past when I had to do more serious jobs like engine swaps, so I am probably gonna ask him to use the space but can't guarantee it is available yet. That said, I've also dropped BMW subframes without a lift before. Had to do it on my buddy's M3 for bushing upgrades and it was 100% pain in the ass and required some creativity - we ended up lowering it with a jack onto some 2x4s and sliding it out on those.
                      I know you get miles of room to work on the turbo if you drop the front subframe for the n-series, so I'm definitely planning on it. I just need to source alignment pins for re-installation.
                      I have heard nothing but great things about power on these bigger turbos at 15-17 psi. My initial plan for sure is going to run a baseline around that boost because it's safe on 93 octane, and then move up from there into likely a 30% e85 mix give or take. I know some people try to stretch it with LPFP upgrade and flex fuel wires but truly port injection is absolutely necessary to get beyond the fueling limitations of these cars. If you're going for more serious power, it was definitely a solid move installing the Motiv kit.
                      Rest assured I'll be updating this thread with details and photos of the install process. There will likely just be a lot more things to laugh at if I'm doing it on the floor 😉
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                        Message Chris Welter either on Facebook or here, he has a big single swap with port injection. he might have some tips, he did it all himself. It's intense to ride in. AWD too.
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          small but highly related update: my turbo is done and will be shipping out tomorrow, with a $125 discount to pricematch the sale at n54tuning.com. I've got a couple months to get it installed so I am likely going to start off trying to get it without removing the front subframe. There are some pretty good N54 DIY documents online of people doing it that way, so I'm going to try and model off of that and see what happens. If push comes to shove, well, I've got an engine hoist so I'll drop the subframe if i have to.
                          I will be picking up a JB4 as well and running the BMS Cobb back-end flash with JB4 running on top of it as that seems to be the defacto standard for anyone running a stage2 turbo on these cars.
                          in other build news, after a month of sitting in my garage, I was finally able to get the Miata to crank over (warm enough) and take it for a rip. The wire gauge end of the negative battery cable has a loose ground as it was relocated to the trunk and just kinda shoved into a metal bracket that's bolted down for grounding, but honestly it really needs to be soldered together. I took Stuart with me because who the hell knew what would happen - and sure enough we made it about 1000 yards before the car died and needed a bump start, lol. Battery cable just came right out. But for those 1000 yards the car built boost and made power and definitely sounded great.
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            Any reason why you don't ditch the COBB for MHD? Apparently JB4 + MHD is the way to go, and it's cheaper.
                            Also, Miatas come with the battery in the trunk from the factory 😄
                            • i_love_carsI
                              i_love_carsI
                              i_love_cars
                              that is inaccurate. I'm on an N55, in which case there is a rough outline of "Q2 2016" for MHD support.
                              The prescribed way of tuning on a large turbo N55 is with BMS's Cobb backend flash and JB4 ISO.  There is a monstrous thread on this at N54tech : http://www.n54tech.com/forums/showthread.php?t=24788
                              and my car came with a Cobb AP already so even if MHD was an option for N55, it wouldn't be any cheaper cuz I've already got the AP unit.  JB4 ISO with the Cobb back-end flash from Terry is good for north of 500 whp with e85 and meth. Don't really need MHD for more gains even if it were fully fleshed out and developed for the N55.  If I wanted to go beyond 500 whp I'd be waiting for the new single turbos that are in development for N55 from Motiv.
                              2007 Z4MR
                              2003 E39 M5
                              2002 E46 M3
                              2021 X5 40i
                                there are like 3 in my area, I'm really good friends with a couple of the dudes that own them.
                                (2 are supercharged, one is turbo all are e85)
                                they autox'd with me. those terbo miatas are a riot!
                                  ...I forgot that you were N55. Doh!
                                  I need to see this car in person some time. Wouldn't mind see what 500whp is all about either.
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    you forget because you're spoiled with N54 lol F my life ;(
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                    • i_love_carsI
                                      i_love_carsI
                                      i_love_cars
                                      so after a minor delay due to my inlet pipe not being ready, turbo is now in transit and will be delivered on Tuesday next week.
                                      After talking with Hallway Pat for a bit I decided it would be wise to pick up a cheaper set of coilovers (BC Racing BR series) for $950 shipped. So I ordered those on Saturday. This will allow me to fix my bro-status ghetto drop that I've been suffering with my H&R sport springs, and hopefully help stabilize the power delivery of the new turbo.
                                      2007 Z4MR
                                      2003 E39 M5
                                      2002 E46 M3
                                      2021 X5 40i
                                      • i_love_carsI
                                        i_love_carsI
                                        i_love_cars
                                        I had a couple hours free tonight from 9-11 so I started disassembling the car. I'm definitely dropping the subframe. Got under the car and took about 4 seconds to realize it would be insanity to install a turbo on this thing without removing subframe.
                                        Unraveled
                                        Sway bar removed, upper and lower control arms disconnected from subframe, steering rack ends disconnected from wheel hub:
                                        Will hoist the engine tomorrow and just need to remove the steering rack bolts, 6 subframe bolts, and engine mount bolts, then the subframe will come down. Tomorrow I expect to finish disassembly so I can ship my OEM turbo to PURE right away to get my core charge refunded.
                                        2007 Z4MR
                                        2003 E39 M5
                                        2002 E46 M3
                                        2021 X5 40i
                                        • Chris WelterC
                                          Chris WelterC
                                          Chris Welter
                                          Its not as bad as it looks.  I think I had my subframe dropped in about 3 hours (my first time doing it) and I have Xdrive.  I think the whole turbo removal process took me about 4 for what its worth.
                                          2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
                                          2002 Suburban: DD and toy hauler.
                                          1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
